6473 Discussions
Error: Compiler Error, not able to generate hardware
JNova9
I needing help with this error: "Error: Compiler Error, not able to generate hardware". I compiled my projet (OpenCL for fpga-bdx-opencl), and the file ".aocx" not created. Someone helpe me this case? please?
Bellow show the all text the file "build.log".
aoc hello_world.cl In file included from <built-in>:11140: <command line>:2:30: warning: ISO C99 requires whitespace after the macro name #define ACL_BOARD_bdw_fpga_v1.0 1 ^ <command line>:3:31: warning: ISO C99 requires whitespace after the macro name #define AOCL_BOARD_bdw_fpga_v1.0 1 ^ 2 warnings generated. Compiler Warning: Limiting maximum work-group size to 512 in function hello_worl d(...) to support private memory. Error: Compiler Error, not able to generate hardware
Thanks a lot.
João Paulo.
HRZ
Valued Contributor III
Such queries are best suited for the "High level Design" forum. Either way, check the "quartus_sh_compile.log" generated by the compiler for more info as to why the compilation failed.
