6468 Discussions
Error during synthesis of MAX 10 FPGA Development Kit sample project 'ddr3x24' in Quartus 20.1.1
Miles1
I'm using the sample project 'ddr3x24' provided by the MAX 10 FPGA Development Kit. My Quartus version is 20.1.1. However, I'm getting the following error during synthesis. Can you please help me to resolve this issue?
Error (12006): Node instance "error_adapter_0" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002_error_adapter_0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_s0_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_001" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_s0_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_002" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_s0_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
AdzimZM_Intel
I believe the Max 10 sample project ddr3x24 is build in legacy Quartus version.
So you may need to perform IP upgrade first before running compilation process.
You have to make sure that the IP upgrade is running successfully.
Adzim
Miles1
Does the update of this IP affect Quartus Prime Lite Edition and Quartus Prime Standard Edition?
AdzimZM_Intel
IP upgrade will update the IP that available in that particular Quartus version.
The newer Quartus version might have some new features added into the IP.
I have tried to replicate the issue at my end but I can successfully run the compilation after upgrading the IPs.
Are you not able to perform IP upgrade?
Adzim
Miles1
I am encountering a different error after updating the IP while using Quartus Prime Lite Edition 21.1.0 .
Error (12006): Node instance "mm_bridge_slv_m0_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_descriptor_slave_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_descriptor_slave_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "prbs_pattern_generator_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "prbs_pattern_checker_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "freq_counter_0_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "timer_0_s1_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "status_mon_0_slv_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mm_bridge_slv_m0_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_descriptor_slave_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_descriptor_slave_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "prbs_pattern_generator_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "prbs_pattern_checker_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "freq_counter_0_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "timer_0_s1_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "status_mon_0_slv_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_003". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_003". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_009" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mm_bridge_slv_m0_limiter" instantiates undefined entity "altera_merlin_traffic_limiter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_descriptor_slave_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_descriptor_slave_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "prbs_pattern_generator_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "prbs_pattern_checker_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "freq_counter_0_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "timer_0_s1_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "status_mon_0_slv_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux_006". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux_006". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_descriptor_slave_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_descriptor_slave_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_write_descriptor_slave_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "dispatcher_read_descriptor_slave_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "async_fifo" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "async_fifo_001" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "async_fifo_002" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "async_fifo_003" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_001" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_004" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_005" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_006" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_007" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter_008" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "s0" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_s0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "c0" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_c0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_driver_msgdma_0_avalon_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "msgdma_0_mm_bridge_slv_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_driver_msgdma_0_avalon_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "msgdma_0_mm_bridge_slv_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_0_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_0_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_0_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "crosser" instantiates undefined entity "altera_avalon_st_handshake_clock_crosser". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "crosser_001" instantiates undefined entity "altera_avalon_st_handshake_clock_crosser". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "msgdma_0_dma_read_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "msgdma_0_dma_write_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mem_if_ddr3_emif_0_avl_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "msgdma_0_dma_read_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "msgdma_0_dma_write_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mem_if_ddr3_emif_0_avl_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_1_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_1_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mm_interconnect_1_router_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mem_if_ddr3_emif_0_avl_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_demux_001" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_mux_001" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mem_if_ddr3_emif_0_avl_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "mem_if_ddr3_emif_0_avl_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_1_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_0_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "product_info_0_avalon_slave_0_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_driver_msgdma_0_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_0_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "product_info_0_avalon_slave_0_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_driver_msgdma_0_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_2_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_2_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mm_interconnect_2_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "master_0_master_limiter" instantiates undefined entity "altera_merlin_traffic_limiter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "cmd_mux_001" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_demux_001" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Info (144001): Generated suppressed messages file D:/work/Code/RTL/MAX10/PS2321_EMB/MAX10_DDR3/ddr3x24/output_files/ddr3.map.smsg
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 129 errors, 23 warnings
	Error: Peak virtual memory: 5042 megabytes
	Error: Processing ended: Wed Apr 12 17:32:14 2023
	Error: Elapsed time: 00:00:47
	Error: Total CPU time (on all processors): 00:00:50
Error (293001): Quartus Prime Full Compilation was unsuccessful. 131 errors, 23 warnings
Miles1
I have resolved the issue by using Quartus Prime Lite 20.1.1 version and updating the IP.
Miles1
By the way, is this IP free of charge?
DDR3 SDRAM Controller with UniPHY Intel FPGA IP
Name
altera_mem_if_ddr3_emif
Version
20.1
Author
Altera Corporation
Description
AdzimZM_Intel
The DDR3 SDRAM Controller is included in IP Base Suite license.
You may need to verify if you have fully installed Quartus software with the IP Base Suite license.
You may contact with your local sales representative to get the full license.
Link for IP Base Suite: https://www.intel.com/content/www/us/en/products/programmable/intellectual-property/ip-base-suite.html
Adzim
Miles1
What are the differences in cost and content between Fixed and Float in Quartus Prime? Also, where can I find the pricing information?
AdzimZM_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
