I am using Quartus standard to create a NIOS II project, once I've created the project and build it it gives me this error, even while using a very simple hello world.
Please help
Hi Amanda,
Due to insufficient memory size in .qsys file, Eclipse® assembler is not able to fit the software regions in that memory. Do the following steps to end this:
1- Go to your Platform Designer (Qsys®) project.
2-Open the on-chip memory properties.
3- Increase the memory size to a value that fits the design and doesn't exceed the available memory size mentioned in the datasheet.
4- Recompile the Quartus® project.
5-Regenerate the BSP and rebuild the application.
Hi Amanda,
