I'm using SoM system for my baremetal project now.
Here is the image of this board:
It has an eMMC flash as a boot option.
I don't know what is the boot flow for this device. So I assume boot form eMMC is kind of boot form SD/MMC card using cycloneVsoc dev kit.
In order to that I'm tyrying to use SPL,since preloader is no longer supportted.
what I did:
1. compile the axf file and then compile the bin file using fromelf(ARMCC tool chain)
2. compile the sof system file using Quartus Prime 22.1std
3. compile the SPL file using Uboot and cycloneVsoc defconfig to get u-boot-spl.
4. made an image from rocketboards.org for the SD card.
I read the AN709 file: baremetal for SD card.
I think what I need to do next is:
Using mkimage to add a load point and an entry address. In baremetal example helloworld, you used order like:
"We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Thank you for your understanding."
As I have mentioned on the other post-https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Bootrom-debug-failed-to-find-spl-in-emmc-CycloneVsoc/m-p/1638333#M28424
we don't have any documentation or steps for BareMetal application booting from eMMC on cyclone V.
However, you are referring the AN709 which is based on the HWLIB GNU based examples.
In order to run the SDcard, QSPI booting examples presented in this Boot Guide the following are required:
• Altera® Cyclone V Development Kit, Rev D
• Host PC running Windows 7 or newer(1)
• Altera SoC Embedded Design Suite (SoC EDS), v14.1 installed
• Altera Complete Design Suite (ACDS) v14.1(2)
spl.boot.SDMMC_NEXT_BOOT_IMAGE = 0x40000. This is the location where the bare-metal application image is stored.
Tiwari
Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
