Just very simple question, may not simple aswer...
It would be feasible implementing sharp lr3692 lcd controller on max2 cpld as substitute?.
Im not sure since seems sharp chip have some microcontroller like block behavior inside.
Thanks!
- Tags:
- Max2
You may use any LCD as long as you have the controller IP(verilog or vhdl) to program inside MAX10.
regards,
Farabi
Thanks in advance for your answer. I know i can usea any lcd as long as i have the controller. The question here is replacing the actual lr3692 sharp ic with cpld. If it is feasible for max ii family or not
You will need to refer to the Max II Handbook to ensure it is meeting the clock speed, Fmax and also the I/O standard available. It should be feasible Max II have similar electrical specifications needed with the LR3692.
Refer to below links for the relevant documentations for MAX II support:
I wish to follow up on this thread. Do you have further questions or support needed?
Thank you.
Sadly the project is not feasible as involves other stuff as form factor and routing
Thanks anyway
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
apparently LR3692 contains only digital functions of a LCD controller, analog display driver are external to it. In so far it should be possible to implement it in CPLD. Not sure if largest MAX II or MAX V with 2210 LE will be sufficient.
Also LR3692 is 5V device, there's no recent 5V capable CPLD with sufficient logic resources on the market.
Frank
