6472 Discussions
HPS BareMetal LED toggle Example for Altera Cyclone V Developement Ki
Chandrashekhar_K
Kindly share working example to toggle LED/GPIO of HPS
Kit : Cyclone V SoC Development Board
Platform : Bare Metal
mabdrahi
I will try to find, test on my side and give my reference project to you
mabdrahi
I found the useful reference about the project
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/ug_cv_soc_dev_kit.pdf
I will try this at my end
mabdrahi
Can you try this example?
https://www.rocketboards.org/foswiki/pub/Projects/LEDBlink/led_blink.tgz
Is it suit with your project?
Chandrashekhar_K
Hi Mabdrahi,
Thank you3 for sharing the document and the  LED example.
I think the example is for linux environment.
It would be of great help if the code for bare metal is available.
Thank You
mabdrahi
I found a useful link for you to try.
https://www.rocketboards.org/foswiki/Documentation/HWLib
mabdrahi
Any update at your end?
Chandrashekhar_K
I could get a sample example from the community, struggled a bit to get it complied.
Now the LED example is working.
Thank you.
mabdrahi
Hi Chandra,
I hope you doing well,
Any stuck or progress status on your end?
mabdrahi
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ALTERA-INSUPPORT22
Assistance Needed: Trouble Running Bare-Metal Code on Cyclone 5 HPS
I am working on intel cyclone 5 hps I have two cores in a processor Core 0 core 1, I want two code to run on two different cores core 0 and core 1 in bare metal .
When I run in jtag mode it works, for jtag i first debug using core 0 where i take core 1 out of reset it, than debug core 1 usign jtag it work
BUT, When i want to run both core usign qspi it only run core 0 not core 1
Here is the step i followed
Firsly, loading preloader
quartus_hps -c 1 -o P preloader-mkpimage.bin
I make an image from bin file of core 0 and place it to qspi
mkimage -A arm -O u-boot -T standalone -C none -a 0x00060000 -e 0 -n "baremetal image" -d core0.bin core0.img
quartus_hps -c 1 -o P -a 0x00060000 core0.img
I make an image from bin file of core 1 and place it to qspi
mkimage -A arm -O u-boot -T standalone -C none -a 0x00100000 -e 0 -n "baremetal image" -d core1.bin core1.img
quartus_hps -c 1 -o P -a 0x00100000 core1.bin
When i restart board only that code work which is in core 0, core 1 code not executing
I am setting cpu1startaddress 100000 apart from that in the code of core 0 also i am using alt_qspi function to to place bin file data in ddr,
I want to run in smp mode so I also set required aux_control_register smp and fw bit as stated in tech ref manual
alt_qspi_read((uint32_t *)BL_START/*ddr3 address*/, 0x100000/*qspi address*/, 0x40000);
In linker/scat file core 0 entry point is 0x60000 and
linker/scat file core 1 entry point is 0x100000
