6472 Discussions
Hi, I am working on reliability prediction of a hardware. This hardware has the following devices: -EP4CGX30CF23C -10CX150YF672I6G Please, could you send me the realibility data (FIT/MTBF) of those devices. Best Regards
RSous3
NurAiman_M_Intel
Hi RSous3,
Thankyou for contacting Intel Community.
To know the MTBF or Failure-in-time rate (FIT), you may refer to the following solution:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04072012_59.html
You can find the FIT rate for Altera devices in the Reliability Report. Kindly be noted that the FIT rate for devices within the same family with the same process technology will be very similar and can be used for devices not explicitly listed in the Reliability Report.
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/rr/rr.pdf
Hope this help!
Thank you.
Aim
RSous3
Thank you very much. Those links help me a lot.
NurAiman_M_Intel
Thank you for the reply. I will now close this case.
Aim
