6469 Discussions
How can I simulate dedicated high speed clock input pins in HyperLynx by FPGA's IBIS model?
LFang7
I download  EP4SE530's IBIS model, but I can not find the dedicated high speed clock input pins in the model. The pin name is CLK[1,3,8,10]. So how can I simulate dedicated high speed clock input pins in HyperLynx by FPGA's IBIS model?IBIS model list.png
Yours,
Longyu
YuanLi_S_Intel
Hi Fang Longyu, There is no dedicated IBIS model for these pin. Since the I/O Standard in Intel PSG FPGA is programmable, you may use the I/O standard that you choose for that input clock pin as the IBIS model. Example: if you use 2.5V I/O standard, you can use 2.5Vcmos IBIS model. Regards, YL
YuanLi_S_Intel
