6330 Discussions
How come the Eclipse gives me this error: .sopcinfo file is missing
ABola2
I've downloaded a NIOS2 project example and imported a software to the Eclipse. after I build the project it gives me the following error : Error: ” .sopcinfo file is missing.”
Can you help?
Ahmed_H_Intel1
Sorry Amanda for confusing you I've replied to the wrong thread. Your issue is a bit easier :) To fix this, follow the next steps: 1. Import the eclipse project o Import-> Nios® II Software Build Tools Project ---> Import Nios® II Software Build Tools Project o Start NIOS® II and select work-space to 'software' folder o Import project code. Select folder for this, and make sure name of project matches folder. o Import BSP files. Select folder for this and again make sure name matches folder. 2. Edit the make file (variable name SOPC_FILE=) and settings.bsp file (Tag name SopcDesignFile=) such that we are pointing to the correct directory of .sopcinfo file.
sstrell
For Nios designs, you need two projects in Eclipse: the BSP based on the .sopcinfo file from Platform Designer and your design project. Did you create a BSP project?
#iwork4intel
AnandRaj_S_Intel
Hi @ABola2​ ,
We may face such issue when we try import the project in different work-space than quartus project directory.
To avoid warning or error ".sopcinfo file is missing"
  1. Recreate the eclipse project with sopcinfo file or
  2. Import the eclipse project and edit the make file (variable name SOPC_FILE=<DIRECTORY>) and settings.bsp file (Tag name SocpDesignFile=<DIRECTORY>) such that we pointing correct directory of socpinfo file.
Which compile/build the project without error/warning.
For existing projects make sure make & settings.bsp files point to correct sopcinfo file.
import the project and build it.
Steps to import the eclipse project
Import-> Nios II Software Build Tools Project ---> Import Nios II Software Build Tools Project
Start NIOS and select work-space to 'software' folder
or
Zip the software folder and import.
Import->general->existing project into work-space->next->select archive file->finish.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
Ahmed_H_Intel1
Hi Amanda, The header checksum appears to be generated with the image checksum zeroed out, and then the image checksum is calculated from the end of the header for the number of bytes specified in the mkimage header. Use the following calculations for verification: UINT32 IMAGECRC32(UINT8 * buf, UINT32 length) { static const UINT32 crc_table[256] = { 0x00000000, 0x77073096, 0xee0e612c, 0x990951ba, 0x076dc419, 0x706af48f, 0xe963a535, 0x9e6495a3, 0x0edb8832, 0x79dcb8a4, 0xe0d5e91e, 0x97d2d988, 0x09b64c2b, 0x7eb17cbd, 0xe7b82d07, 0x90bf1d91, 0x1db71064, 0x6ab020f2, 0xf3b97148, 0x84be41de, 0x1adad47d, 0x6ddde4eb, 0xf4d4b551, 0x83d385c7, 0x136c9856, 0x646ba8c0, 0xfd62f97a, 0x8a65c9ec, 0x14015c4f, 0x63066cd9, 0xfa0f3d63, 0x8d080df5, 0x3b6e20c8, 0x4c69105e, 0xd56041e4, 0xa2677172, 0x3c03e4d1, 0x4b04d447, 0xd20d85fd, 0xa50ab56b, 0x35b5a8fa, 0x42b2986c, 0xdbbbc9d6, 0xacbcf940, 0x32d86ce3, 0x45df5c75, 0xdcd60dcf, 0xabd13d59, 0x26d930ac, 0x51de003a, 0xc8d75180, 0xbfd06116, 0x21b4f4b5, 0x56b3c423, 0xcfba9599, 0xb8bda50f, 0x2802b89e, 0x5f058808, 0xc60cd9b2, 0xb10be924, 0x2f6f7c87, 0x58684c11, 0xc1611dab, 0xb6662d3d, 0x76dc4190, 0x01db7106, 0x98d220bc, 0xefd5102a, 0x71b18589, 0x06b6b51f, 0x9fbfe4a5, 0xe8b8d433, 0x7807c9a2, 0x0f00f934, 0x9609a88e, 0xe10e9818, 0x7f6a0dbb, 0x086d3d2d, 0x91646c97, 0xe6635c01, 0x6b6b51f4, 0x1c6c6162, 0x856530d8, 0xf262004e, 0x6c0695ed, 0x1b01a57b, 0x8208f4c1, 0xf50fc457, 0x65b0d9c6, 0x12b7e950, 0x8bbeb8ea, 0xfcb9887c, 0x62dd1ddf, 0x15da2d49, 0x8cd37cf3, 0xfbd44c65, 0x4db26158, 0x3ab551ce, 0xa3bc0074, 0xd4bb30e2, 0x4adfa541, 0x3dd895d7, 0xa4d1c46d, 0xd3d6f4fb, 0x4369e96a, 0x346ed9fc, 0xad678846, 0xda60b8d0, 0x44042d73, 0x33031de5, 0xaa0a4c5f, 0xdd0d7cc9, 0x5005713c, 0x270241aa, 0xbe0b1010, 0xc90c2086, 0x5768b525, 0x206f85b3, 0xb966d409, 0xce61e49f, 0x5edef90e, 0x29d9c998, 0xb0d09822, 0xc7d7a8b4, 0x59b33d17, 0x2eb40d81, 0xb7bd5c3b, 0xc0ba6cad, 0xedb88320, 0x9abfb3b6, 0x03b6e20c, 0x74b1d29a, 0xead54739, 0x9dd277af, 0x04db2615, 0x73dc1683, 0xe3630b12, 0x94643b84, 0x0d6d6a3e, 0x7a6a5aa8, 0xe40ecf0b, 0x9309ff9d, 0x0a00ae27, 0x7d079eb1, 0xf00f9344, 0x8708a3d2, 0x1e01f268, 0x6906c2fe, 0xf762575d, 0x806567cb, 0x196c3671, 0x6e6b06e7, 0xfed41b76, 0x89d32be0, 0x10da7a5a, 0x67dd4acc, 0xf9b9df6f, 0x8ebeeff9, 0x17b7be43, 0x60b08ed5, 0xd6d6a3e8, 0xa1d1937e, 0x38d8c2c4, 0x4fdff252, 0xd1bb67f1, 0xa6bc5767, 0x3fb506dd, 0x48b2364b, 0xd80d2bda, 0xaf0a1b4c, 0x36034af6, 0x41047a60, 0xdf60efc3, 0xa867df55, 0x316e8eef, 0x4669be79, 0xcb61b38c, 0xbc66831a, 0x256fd2a0, 0x5268e236, 0xcc0c7795, 0xbb0b4703, 0x220216b9, 0x5505262f, 0xc5ba3bbe, 0xb2bd0b28, 0x2bb45a92, 0x5cb36a04, 0xc2d7ffa7, 0xb5d0cf31, 0x2cd99e8b, 0x5bdeae1d, 0x9b64c2b0, 0xec63f226, 0x756aa39c, 0x026d930a, 0x9c0906a9, 0xeb0e363f, 0x72076785, 0x05005713, 0x95bf4a82, 0xe2b87a14, 0x7bb12bae, 0x0cb61b38, 0x92d28e9b, 0xe5d5be0d, 0x7cdcefb7, 0x0bdbdf21, 0x86d3d2d4, 0xf1d4e242, 0x68ddb3f8, 0x1fda836e, 0x81be16cd, 0xf6b9265b, 0x6fb077e1, 0x18b74777, 0x88085ae6, 0xff0f6a70, 0x66063bca, 0x11010b5c, 0x8f659eff, 0xf862ae69, 0x616bffd3, 0x166ccf45, 0xa00ae278, 0xd70dd2ee, 0x4e048354, 0x3903b3c2, 0xa7672661, 0xd06016f7, 0x4969474d, 0x3e6e77db, 0xaed16a4a, 0xd9d65adc, 0x40df0b66, 0x37d83bf0, 0xa9bcae53, 0xdebb9ec5, 0x47b2cf7f, 0x30b5ffe9, 0xbdbdf21c, 0xcabac28a, 0x53b39330, 0x24b4a3a6, 0xbad03605, 0xcdd70693, 0x54de5729, 0x23d967bf, 0xb3667a2e, 0xc4614ab8, 0x5d681b02, 0x2a6f2b94, 0xb40bbe37, 0xc30c8ea1, 0x5a05df1b, 0x2d02ef8d }; UINT32 crc = 0xffffffff; while(length--) { crc = crc_table[((int)crc ^ (*buf++)) & 0xff] ^ (crc >> 8); } return crc ^ 0xffffffff; }
Ahmed_H_Intel1
ABola2
Thanks a lot Embedded Guy, this solved my problem completely.
