6409 Discussions
How could I cool down my pac board N3000-2 and how to check or modify the mode of fan?
ahaa
When I powered on my N3000-2 and excuted the command of 'fpgainfo temp' to get its temperature info,I found its temp was so high and had a sharp rise, almost to the thresholds of 100℃(FPGA core) or 85℃(Board). And it would shutdown automatically when reached the threshold.
And we found that maybe we could set the speed of fan in the board to cool down the board from the user guide manual, but we don't know how to do it exactly?
And how to check or modify the mode of the fan(cooling device)?
Is there anyone knows or gives some solutions to us? Thank you very much!
JonWay_C_Intel
You will have to check with the server vendor. Each vendor method of setting the fan speed is different.
ahaa
the problem had been solved now, thanks for your reply
