6411 Discussions
I am looking for a modulo n counter with a real reset in vhdl; thank you for your reply .
GMogn
Rahul_S_Intel1
Hi ,
I will paste the sample counter program for your reference , make changes as per your requirement
library IEEE;
use IEEE.NUMERIC_STD.all;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity scale_clock is
 port (
  clk_50Mhz : in std_logic;
  rst    : in std_logic;
  clk_2Hz  : out std_logic
end scale_clock;
architecture Behavioral of scale_clock is
 signal prescaler : unsigned(23 downto 0);
 signal clk_2Hz_i : std_logic;
begin
 gen_clk : process (clk_50Mhz, rst)
 begin -- process gen_clk
  if rst = '1' then
   clk_2Hz_i  <= '0';
   prescaler  <= (others => '0');
  elsif rising_edge(clk_50Mhz) then  -- rising clock edge
   if prescaler = X"BEBC20" then   -- 12 500 000 in hex
    clk_2Hz_i  <= not clk_2Hz_i;
   else
    prescaler <= prescaler + "1";
   end if;
end if;
 end process gen_clk;
clk_2Hz <= clk_2Hz_i;
end Behavioral;
GMogn
Hi , Thank you for your help, I will adapt this program to my application. Cordialement Gilles MOGNOT Electronic Automotive Manager Engineer GMConcept 22,Allée du Jasmin 95130 FRANCONVILLE Tel : 01.30.72.10.00 Port : 06.07.08.07.51 <mailto:gilles.mognot@gm-concept.com> gilles.mognot@gm-concept.com
GMogn
Hello Rahul,
Have you in bibliotheque a Vhdl converter decimal to Hexadecimal?
Best regards Gilles
Rahul_S_Intel1
Hi Gilles,
With the above , I am closing the tread if you u have any other questions.
Rahul S
Rahul_S_Intel1
Hi Gilles,
Thanks for the update , I am sorry to let you know , I am not familiar with french words. So I am assuming bibliotheque as library ( got from google).
If I am rewriting your question, is there any library to convert VHDL to Hexadecimal .
In my point of view the conversion of VHDL to binary or machine ( device ) depended is done by the tool which is provided from the Vendors .
GMogn
Hi Rahul,
This is a decimal to hexadecimal to Vhdl converter for Quartus 14.1_Max 5
Best regards Gilles
Rahul_S_Intel1
Hi ,
In my knowledge there is not converter from Decimal to Hexadecimal to VHDL ( Decimal >> Hexadecimal >> VHDL)
Altera is not providing any tool for the conversion to decimal to VHDL
