6204 Discussions
IC FPGA - EP4CE40F23C8N -Urgent
Martin_11
IC FPGA - EP4CE40F23C8N has a maximum number of single-ended digital inputs/ outputs of greater than 700 where in this context, the maximum number of digital inputs/outputs is also referred to as the maximum user inputs/ outputs or maximum available inputs/outputs, whether the integrated circuit is packaged or bare die.
FvM
Honored Contributor I
not sure what your actual question is. You are asking about a specific FPGA device in F484 BGA package. According to device overview document, it has 324 user I/O pins available. Same die is also offered in F780 BGA package with 532 user I/O pins. For detalis of pin functionality you can refer to pinout tables.
Frank
Martin_11
Please clarify on whether the product has a maximum number of single-ended digital inputs/outputs of greater than 700?
Please clarify whether the product has an ‘aggregate one-way peak serial transceiver data rate’ of 500 Gb/s or greater?
FvM
Neither.
324 < 700
EP4CE series has no GBit transceivers at all.
AqidAyman_Intel
AqidAyman_Intel
I wish to follow up with you.
Do you have any more questions on this?
