5954 Discussions
Implementing adc on cyclone 5
implemented the module according to manual i was able to run the program successfully but i am not able to find the output
may be i assigned the pins in wrong way can anyone suggest me to which pin i should assign the following adc_sclk and adc saddr , adc cs and adc sdat
thank you
Hi Maheshbimaq,
1.In signaltap are you able to see the input signal? Check the input source.
2.In signaltap have you set trigger conditions?
3.ADC_SCK PIN_V10, ADC_SDO PIN_AD4, ADC_SDI PIN_AC4 & ADC_CONVST PIN_U9.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
thank you
--- Quote End ---
This depends on what board you are using. Refer to the manual provided by the manufacturer (likely Terasic). They list all the FPGA pin connections for on-board devices.
thank you for your reply!
do i need to set this trigger condition after i mount my output file(sof) on FPGA?
can you tell me how to set the trigger condition because i am new to this tool and do you have any material for this so that i can learn
i have done the pin assignment correctly the problem is i am not able to set the trigger condition i dont have any experience with this tool so it will be easier for me if have any manual or steps to follow
so please could you help me
Hi
Go through the user guide of signal-tap for more information also check the below links
https://www.youtube.com/watch?v=llodw5in4pg
https://www.altera.com/support/training/course/odsw1171.html
https://www.youtube.com/watch?v=vhkzxcexuaa
Can you attach your observed output window image.
Anand Raj Shankar
https://www.alteraforum.com/forum/attachment.php?attachmentid=14506
so in was able to see my nodes on analyzer....can you suggest me which condition should i give to see the output
Understand the hardware and user manual.
Trigger on the clock at which ADC Data is changing/sampling.
or
trigger the data itself(led(0..7)) for checking it.
Anand Raj Shankar
https://www.alteraforum.com/forum/attachment.php?attachmentid=14519
i want to read a analog input on 2*5 adc header i followed the module ....in the manual it says use pot (variable resistor) and it says run test.bat file but when i do it shows some value from channel 7 but i have connected to channel 0 of adc or can you tell me if i am going wrong ?
my question is how do i change it to channel 0
Hi
Have you "Set SW[2:0] = 000, to measure channel 0 of ADC"?
Anand Raj Shankar
successfully done with ADC part!!
i have one more question is it possible to read a analog output on GPIO by connecting additional circuitary (DAC)
for example i want to apply analog signal on 2*5 adc header and read that on GPIO
is it possible?
thank you
Mahesh
--- Quote Start ---
is it possible?
thank you
Mahesh
--- Quote End ---
Yes, you can use additional circuitry.
While selecting DAC circuitry take care on LSB/Resolution of DAC and GPIO capability.(i.e Whether you can detect the LSB change?)
Anand Raj Shankar
is there any example related to this where i can understand something and implement ?
and i am planning to use ic ad421 which is a dac ( external circuit )to convert digital signal on gpio to analog
ADC IS 12BIT resolution which is inbuilt so
reading an input signal on 2*5 header is done !
how can i read the same analog signal on GPIO?
just similar to connecting to leds on board ?
or there is any other technique
or should i use pwm?
if there are any example it will help me alot
1.You should have DAC resolution of at least 12 or greater is better keeping verf in consideration and also the driving strength.
2.Chose a board/Design like that, You can find the some martials from terasic for other board/daughter boards which will help you to understand requirements for your board.
Check the board below
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=67&no=278
https://www.altera.com/content/dam/altera-www/global/en_us/portal/dsn/42/doc-us-dsnbk-42-5008051605255-d8m-gpio-user-manual.pdf
Anand Raj Shankar
