MAX 10 configuration device
ZBien
I use Quartus Lite Prime Edition - 18.1.
I want to use Parallel Flash Loader to configure and program an external QSPI memory device for MAX 10 FPGA.
But on the menu: Assignments -> Device -> Device and Pin Options, on Configuration scheme - I only get: Internal Configuration option which is suitable only for internal MAX 10 FLASH memory.
If I change the device type to Cyclone, I do get Active Serial, which is suitable for external QSPI memory device.
But I want to use MAX 10 and I want to use external FLASH memory and not internal FLASH memory.
Please advice.
SreekumarR_G_Intel
MAX 10 FPGA only support internal configuration and JTAG in-system configuration. You can boot the FPGA from the on chip flash and you can do normal JTAG configuration on the FPGA . i am sure max 10 internal flash is enough memory to store the logic. I do not think MAX 10 supports AS configuration for FPGA as it is not stated in the user manual.Link below for your reference
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
if you looking for Nios , Kindly follow below application notes which explained all the methods of nios booting
https://www.intel.com/content/www/us/en/programmable/documentation/iga1446487888057.html#fwl1479912385825
thank you ,
Sree
