6474 Discussions
Compatibility between FPGA and DaughterCard
KKont
Greetings,
I'm new to FPGAs, I haven't found anywhere an answer to this. So what I'd like to know is how can I check if a daughter card is compatible to an FPGA
I specifically want to know if these two would work together:
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=167&No=1081&PartNo=1
https://www.vadatech.com/product.php?product=451&catid_now=0&catid_prev=0
(Planning to use this adapter
https://www.kayainstruments.com/hsmc2fmc/#1482656238000-d623c99f-16ee6fd1-b78f
to connect them)
Thanks in advance.
Deshi_Intel
Hi, I can see that you are trying to validate whether certain daughter card can be connected to Terasic DE10-Standard board or not. This is a valid question but unfortunately you post it on the wrong forum as this Intel FPGA forum is designed to handle enquiry related to dev kit board developed by Intel only. You can check with Terasic on consultation with their board usage via Terasic technical support email : support@terasic.com Thanks. Regards, dlim
KKont
Ok thank you and sorry for the mix up.
Deshi_Intel
No problem !
