6460 Discussions
MTBF data of Intel® Cyclone® 10 GX
AStoc3
Hi I was wondering if anyone can provide me data on the MTBF of the Intel® Cyclone® 10 GX part No. 10CX220YF780I5G
Cheers
ChiaLing_T_Intel
Hi, To know the MTBF or Failure-in-time rate (FIT), you may refer to the following solution: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04072012_59.html You can find the FIT rate for Altera devices in the Reliability Report. Kindly be noted that the FIT rate for devices within the same family with the same process technology will be very similar and can be used for devices not explicitly listed in the Reliability Report. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rr/rr.pdf Thank you Regards, Chia Ling
