6474 Discussions
MegaFunction Wizard Import LIbrary - Callback
When I try to import a component into System Contents Library (In SOPC Builder), I got Loading Component with TCL callbacks popup error window:
This Component defines TCL callback functions.
Component Editor does not save TCL callbacks. IF you eidt this component, the callback functions will be removed.
How do I import component into library (SOPC Builder) correctly?
Also how to install a component that can be preloaded into SOPC builder's System Contents LIbrary?
Thank you,
David
