NIOS LICENSE
YYako
I've purchased a nios license about a year and a half ago
About a month ago I've tried to transfer the license to another computer
after generating the licensee from the intel web site and uploaded the dat file I got this massage below
does anybody familiar with this problem?
KhaiChein_Y_Intel
Hi YYako,
Can you provide the following information?
  1. License.dat file
  2. Host ID
  3. Quartus version and edition (Pro /Standard)
YYako
Hi, Attached the license.dat file and host id I'm using the 18.1 quartus version the lite edition [cid:image002.jpg@01D4CCED.73A38A00]
KhaiChein_Y_Intel
Hi YYako,
There is no attachment here. Could you reattach?
Kindly provide the screenshot of License Setup as well.
YYako
KhaiChein_Y_Intel
Hi YYako, I could not find the attached item. Are you attaching via email or web? Thanks
YYako
YYako
i cant upload a file type Dat
YYako
KhaiChein_Y_Intel
Hi YYako,
  1. The Lite edition software does not require license. You may click cancel.
  2. Do you see the NIOS II IP license in the license setup? Can you provide a screenshot?
  3. For the attachment, you may try to zip the file or copy to a .txt file
KhaiChein_Y_Intel
Hi YYako, Any updates? Thanks
YYako
Hi, I've been given a temp licensee for the next 2 months I have a big project coming up so i haven't had the chance to try and fix the problem I will update you next week Thanks
KhaiChein_Y_Intel
YYako
Hi, Sorry, Haven’t had the time to check it yet Get back to you tomorrow after ill check it Thanks'
KhaiChein_Y_Intel
Sure
YYako
It seems to be OK I choose cancel instead of OK and now I can compile my code and produce a SOF FILE Thank you
