6478 Discussions
NIOS2 bidirectional IO port setting
VHou0
Set an 8-bit bidirectional IO port as output mode in NIOS2 code, but only 4 bits (bit 0, 1 ,4 ,5)can output correctly, and the other 4 bits hold out state 0.
Ahmed_H_Intel1
Can you please explain more? what is your issue?
Ahmed_H_Intel1
please check the top level connection first. you can share with us the top level connection and the assigned pins for these LEDs.
VHou0
Thanks you .I removed signaltap from the project, it works correctly.
