6472 Discussions
Need PCB land pattern for part EP4CE6F17C8N
SLB-Aman_Arab
Hello Team,
Please share the recommended land pattern for part EP4CE6F17C8N.
Aman Arab
FvM
BGA pin numbering is alphanumerical (A1..A16, B1..) etc., it's specified in above linked package drawing, please review.
Pinout is described in separate documents, browse https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html
Farabi
Hi Aman,
Please refer to attached package drawing for land pattern recommendation. link : https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/packaging/04R00230-03.pdf
FBGA-256 Ball Grid Array- 0.8mm pitch
Ball pitch = 0.8mm
Pad(Land) Diameter = 0.3mm to 0.35mm
Solder Mask Opening = 0.4mm
Pad Type = NSMD (Non-Solder Mask Defined) recommended
NSMD Pad size = 0.30mm to 0.33mm diameter
Solder Mask Clearance = +0.05mm all around pad
Package size = 17mm x 17mm
regards,
Farabi
SLB-Aman_Arab
Hello Farabi,
Thank you for your response. We kindly request the pin numbering details from pin 1 to pin 256, along with the corresponding pin functions/significance for each. This information is essential for our analysis and proper integration. The details you shared are helpful in understanding the footprint only.
Aman Arab
SLB-Aman_Arab
Hello Team,
Any updates on the requested PINs details?
Aman Arab
FvM
