6464 Discussions
Need technical support for MAX 10 FPGA Development Kit
BXia
To whom it may concern,
Can you please connect us with someone in your technical support department that would help us troubleshoot an issue with your rev b MAX 10 FPGA Development Kit? It looks like a design change was made between rev b and c that involves pin assignments to the DDR3 .
We have a very urgent project that uses this board as a key component. The examples we have for the rev c board and DO NOT work on rev b. We want to install Linux onto the board but all examples including the binary image uses rev c. This results in the rev b board not booting. Please help us find someone that either knows how to install Linux on the rev b or can provide technical support for us to convert the rev c examples over to rev b.
Thanks in advance!
AdzimZM_Intel
Hi BXia,
Sorry for the delay.
I'm Adzim. Thanks for using Intel Community.
Let me states my understanding based on your situation.
Currently, you want to use the Rev B board but the example is limited to Rev C board.
I think that there are some examples for the Rev B board here.
Is it what you're using in your project?
Adzim
AdzimZM_Intel
Hi BXia,
I hope you're doing well.
Do you still have the issue with your board?
Adzim
BXia
Hi Adzim,
Thanks for your reply.
I found no guide or examples in the installation files about how to install Linux on the rev b board, do you have any reference guide or examples?
Thanks again.
AdzimZM_Intel
Hi sir,
You can use the guide from this link.
Please let me know if this can help you.
Adzim
AdzimZM_Intel
Hi Sir,
May I know the update on this case?
Adzim
BXia
Hi Adzim,
Thanks for yur reply, you may close this this thread.
