6468 Discussions
OneAPI installation with FPGA Add-on for A10gx board
vinutha
We are trying to install oneAPI for FPGA Add-on for custom platform using a10gx board.
To achieve this we downloaded and installed the FPGA add-on using Intel Quartus Pro Software package from the Toolkit Download page.
Also the package related to A10gx board was downloaded and installed in /opt/intel/oneapi/intelfpgadpcpp/2021.3.0/board
After installing OneAPI 2021.3 I could setup the environment
$ source setvars.sh
:: initializing oneAPI environment ...
   -bash: BASH_VERSION = 4.4.20(1)-release3
:: advisor -- latest
:: ccl -- latest
:: compiler -- latest
:: dal -- latest
:: debugger -- latest
:: dev-utilities -- latest
:: dnnl -- latest
:: dpcpp-ct -- latest
:: dpl -- latest
:: intelpython -- latest
:: ipp -- latest
:: ippcp -- latest
:: ipp -- latest
:: mkl -- latest
:: mpi -- latest
:: tbb -- latest
:: vpl -- latest
:: vtune -- latest
:: oneAPI environment initialized ::
To diagnose the oneAPI and FPGA installation the sys_check.sh script is executed with errors
$ ./sys_check.sh
Warning: INTEL_FPGA_ROOT is not set.
         Please ensure Intel(R) FPGA Add-on for oneAPI Base Toolkit is installed
         if you want to perform FPGA bitstream generation.
Warning: Open Programmable Acceleration Engine (OPAE) driver was not found.
         If Intel(R) Programmable Acceleration Card with Intel(R) Arria(R) 10 GX
         or Intel(R) Stratix(R) 10 SX FPGA is installed in the system, please
         install OPAE driver by running
             aocl install <board package name or path>
:: vtune -- latest
:: tbb -- latest
..None
ERROR: test_smoke (__main__.TestIntelDistribution) (package='cython')
Traceback (most recent call last):
  File "/opt/intel/oneapi/intelpython/latest/sys_check/sys_check.py", line 72, in test_smoke
    raise err
  File "/opt/intel/oneapi/intelpython/latest/sys_check/sys_check.py", line 69, in test_smoke
    stderr=subprocess.DEVNULL)
  File "/opt/intel/oneapi/intelpython/latest/lib/python3.7/subprocess.py", line 512, in run
    output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command 'python "/opt/intel/oneapi/intelpython/python3.7/pkgs/cython-0.29.23-py37hb3b8d61_0/info/test/run_test.py"' returned non-zero exit status 1.
Ran 3 tests in 6.836s
FAILED (errors=1)
Failed
No Issues Encountered.
Can you please help us to solve this issue and proceed further.
Vinutha
BoonBengT_Altera
Hi @vinutha,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
A few clarification, may I know are you installing on your local machine yes? What would be the OS which you are working on? Any guide that you are following and stuck on?
We do have a details steps here which can walk you through on the installation.
Hope to hear from you soon.
Best Wishes
BB
vinutha
Thanks for the help and to clarify details:
Yes, we are trying to install in our local machine with ubuntu OS 18.04.5 LTS (GNU/Linux 5.4.0-42-generic x86_64).
We have Arria-10 gx board and would like to demonstrate  oneAPI installation using this.
While following the guide mentioned below for
Install the Intel® FPGA Add-on for Intel® Custom Platform
Steps 1 to 8 were successfully executed.
Step 9  $ ./sys_check.sh executed with error. File attached.
Vinutha
BoonBengT_Altera
Hi @vinutha,
Apologies for the delayed in response, currently we are trying the same in container ubuntu to see if that works.
For the time being, would recommend a workaround to use the Intel DevCloud platform that are readily setup.
You would just need to request an access and will be able to compile oneApi example designs, more details on the access can be found here.
Hope that clarify for the time being.
Best Wishes
BB
BoonBengT_Altera
Hi @vinutha,
Good day, just following up on the previous mention workaround.
By any chances did you managed to look into the it?
Best Wishes
BB
BoonBengT_Altera
Hi @vinutha,
Greetings, as we do not receive any further clarification on what is provided, we would assume challenge are resolved. Hence thread will no longer be monitored. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
