Hi, I met an Error when programming the Stratix 10 SX FPGA.
it shows the same as @Ppavan mentioned:
I am using Quartus Prime Pro 19.1
I am using Stratix 10 SX Dev Kit with Device: 1SX280HN2F43E2VG
Thanks for all help!!!
OHHH I solved this problem.
I checked the update package of the d5005 chip and searched for qsf file in openCL hardware manager, and changed power management setting in my project. The core error is a wrong address number of the slave device protected by the openCL interface.
Thanks very much!
Have you tried to use the sof file from dev kit installation package "https://www.intel.com/content/dam/altera-www/global/en_US/support/boards-kits/stratix10/soc/stratix10SX_1sx280uf50_soc_revB_htprd_v19.1_b240_v1.0.zip"?
Yes, I tried them as long as I met the error.
However, the setting in this design is not compatible with the FPGA I want to program onto, so it always fail.
Then I checked the qsf file in this package and reviewed the setting in my project according but it didn't work, too.
Thanks very much!
I am glad that to hear that the issue has been resolved.
I have the same issue with a Stratix 10 Dev Kit. I am so puzzled as to why intel Moderators do not capture the full and detailed solution like Xilinx Answer Records do. That way when others search for this problem and find this they could follow the detailed solution instead of being disappointed that Intel is just happy that Harriet5he found his solution, whatever it is. What about others who have the same issue? I have no idea what the solution is from this thread.
