6473 Discussions
Questions for JTAG signals timing constraints.
RLee42
I'd like to have several Cyclone V FPGA normal PINs, not the ones for altera jtag, as the JTAG signals, and I hope the TCK can work at a 5MHz~10MHz frequency. My questions are as below:
  1. Is there any official recommendation for the timing constraints or settings for the normal PINs when they are used as TCK, TMS, TDI, TDO?------Like max/min input/output delay if needed, and source synchronous may be needed, also TDI and TDO are something like DDIO. How can I handle these things all together?
  2. If I don't assign a dedicated clock PIN for TCK and no special treatments for the JTAG signals, what's the possible maximum frequency of TCK from the side of FPGA?
Thank you.
Ross​
