6478 Discussions
Request for a verilog code to connect PCA9685 to Altera Cyclone IV FPGA based development board
first_rain
Hello
I'm need to control a bunch of servo-motors by a FPGA board (Altera cyclone IV core).  I'm using a PCA9685 as the driver of the motors. I would be greatly tanksful if you could give me some hint or if it's possible a Verilog based example for running the motor driver.
So far I assigned a pwm output from the fpga pin to SCL pin on PCA board, beside the vcc and the ground, I also wired one of the switches as for 0 or 1 to SDA pin assuming that the 0 would chose the servo 1th and the 1 would be choosing the servo number 1. nothing happens so far :)).
Thanks in advance.
first_rain
I would appreciate if someone could help
SyafieqS
Hi Artin,
I found a open source reference related to servo controller that might be heloful. You can refer to link below for details.
https://gist.github.com/mcgodfrey/b94acfc796c240a4a164
first_rain
Hi, thanks for reply however my concern is about controlling the PCA9685 as the i2c to controll the servos.... not direct control.
allthegoodnamesaregon
Are there any updates on the subject, i have the same issue since i'm trying to use the PCA9685 of the adafruit with my de0 nano
