Received my Max 10 Development kit, Rev C, and downloaded the development kit installer.
It (dev kit installer) consists of a zip file. After extracting, but there is no executable to run..... Do I simply create a 'kits' sub directory under my quartus intallation and extract everything there?Link Copied
Hi, take C version for example, if you download this one (see attached Pic 1): You will get a file :max10_10m50daf484c6ges_v15.0.0_RevC.exe, double click
max10_10m50daf484c6ges_v15.0.0_RevC.exe to install it, then, it will releases files(\kits\max10_10m50daf484c6ges_fpga) as below (see attached Pic 2), that is, all files involved in design will be released after process above.
