6477 Discussions
SOC_EDS on windows, can't start the Embendded shell bat
CAlex
New Contributor II
I have problem on opening the Embedded_Command_Shell.bat, when I use power shell to run it, it says:” The system cannot find the path specified.“
I used to use the SOCEDS 18.1 and I uninstalled it and install the EDS 20.1.
How can I fix that problem?
reguards.
CAlex
New Contributor II
Okey, the problem is caused by the cygmw tool chain, I already installed that but you have to re-install that in the folder EDS desired.
Please refer to the SOC EDS user guide Intel offered for detail.
CAlex
New Contributor II
Also, when I use ubuntu to open embedded_command_shell.sh and lanch bsp-editor, it says it's not found.
CAlex
New Contributor II
EBERLAZARE_I_Intel
Glad you worked it out, you may also refer to our KDB search for info incase we are late for responds:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086433.html
https://www.intel.com/content/www/us/en/support/programmable/articles/000089298.html
Also, we recommend that you use the latest flow to create the Bootloader or Cyclone V SoC which does not use bsp-editor:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Cyclone_V_SoC_45_Boot_from_SD_Card
https://www.rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
CAlex
New Contributor II
Sorry if I'm wrong but according to the guide I still need the bsp-editor to get the code if I'm working on the cyclone V ,right?
reguards.
EBERLAZARE_I_Intel
For the latest version you do no need it. It will use the "cv_bsp_generator.py" script to take the sources from the handoff folder instead of the bsp-editor.
EBERLAZARE_I_Intel
Do you have any additional questions?
CAlex
New Contributor II
No,not on this topic anymore.
Thank you
Reguards.
EBERLAZARE_I_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
