- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hi there,
Im need to configurate a SPI interface on a Cyclone V. On the deplyment, i did some measurements and i noted that the SPI_SS_N is not toggling, no matter which flags i use.
int_result=alt_avalon_spi_command(base_address,slave,size,buffer,0,0,ALT_AVALON_SPI_COMMAND_MERGE);
int_result=alt_avalon_spi_command(base_address,slave,size,buffer,size,rx_buffer,0);
also, i configurate also the SPI_CS_n pin on the vhdl code, but it is not working though ...
spi_adf5610_external_MISO => adf5610_spi_sdo,
spi_adf5610_external_MOSI => adf5610_spi_sdi,
spi_adf5610_external_SCLK => adf5610_spi_sclk,
spi_adf5610_external_SS_n => adf5610_spi_csn,
im tested succesfully a similar code on an Arduino. But, in these case the SPI_CS is driven as a GPIO, and the SPI port is enabled/disabled by request.
I wondering if i had to do something similar on the eclipse-nios2 code..
i appreciate any comment or sugestion
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi @giomate,
Thank you for posting in Intel community forum and hope this message find you well.
If i understand the situation correctly, I would recommenad that the following design example might be helpful to your needs.
Please do refer to the 'SPI_Bridge_Design_Example.zip', within the nios2 project there is a references C code to write and read to onchip memory connected via SPI for further details.
Warm regards.
BB
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi @giomate,
Good day, just checking in by any chances did you managed to look into the recommendation above.
Please do let us know if you have any difficulties doing so.
Thank you.
Warm regards
BB
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
hi BoonBeng,
thanks for your support,
at the moment , i got the spi working , when i modified the general SPI transfer function on that way:
void SPI_Handler::Open(void){
IOWR_ALTERA_AVALON_SPI_CONTROL(base_address, ALTERA_AVALON_SPI_CONTROL_SSO_MSK);
void SPI_Handler::Close(void){
IOWR_ALTERA_AVALON_SPI_CONTROL(base_address, 0);
void SPI_Handler::SEN(bool sen){
if(sen){
}else{
however, on higher baudrates(SPI_ADF5610_TARGETCLOCK >4000000u), something is not working...
So , if the system is 80 MHz, how fast can run the SPI?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi @giomate,
Greeting and hope this message find you well, by any chances did you managed to look in documents.
Please do let us know if there is any clarification we can help with.
Warm regards
BB
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi @giomate,
Hope this message find you well and good day, as we do not receive any response from you to the previous clarification that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
BB
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
