6472 Discussions
Need a pin assignments for kit FPGA Cyclone IV EP4CE6E22C8N
Dear Altera,
My name is Phu Nguyen. I am looking for a file pin assignment for kit FPGA Cyclone IV EP4CE6E22C8N. I used to use kit DE2 and have a file exel DE2_pin_assignment but i can't find a file for kit FPGA Cyclone IV EP4CE6E22C8N.
Can you give me or link of file pin assignment for kit FPGA Cyclone IV EP4CE6E22C8N.
I look forward to hearing from you again.
Thank you and best regards,
Phu Nguyen
Hi Phu Nguyen,
Check Pin-Out Files for Intel FPGA Devices at the following link,
https://www.altera.com/support/literature/lit-dp.html?1
For Cyclone IV EP4CE6 Devices refer the following link,
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/cyclone-iv/ep4ce6.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
--- Quote Start ---
Hi Phu Nguyen,
Best Regards
Vikas Jathar
--- Quote End ---
Dear Vikas Jathar,
I have read 02 material which you offer, my problem is although i understand pin of chip but i don't know pin of kit FPGA Cyclone IV EP4CE6.
Can you help me?
Thank you for your time. I look forward to hearing from you again.
Phu Nguyen
Hi Phu Nguyen,
Use E144 Column for pin assignment of FPGA Cyclone IV EP4CE6E22C8N from pdf attached in the previous post.
Refer Cyclone IV Device Handbook.
Best Regards
Vikas Jathar
--- Quote Start ---
Dear Altera,
Phu Nguyen
--- Quote End ---
Can you tell the Kit name/model number. Each Kit Each Altera Kit has specific pin assignment charts. We can get you the pin assignments for your kit once you provide the Kit part number/Model aka, Altera DE1, etc.
first_rain
Hi
I have a chinese board
which on its front is written cyclone IV and  mcc-c  under the clock. then on the core is written
Altera cyclone IV
ep4ce6e22c8n
G ccaaa 1913a
on the back of the board is written Altera development core board
model: MCC-B version V1R1
could you please help me with the pin assignment? I have been trying to findout which pins are connected to the 5 onboard LEDs.
