Set pins current
MDiDo
Hello, I realized an hardware block in vhdl. Is it possible to set the current of the output pins directly in the code or can I do this only through the constraints?
ChiaLing_T_Intel
Hi Marco, You can set the programmable current strength thru the Quartus Assignment Editor. The programmable current strength of each I/O standard can refer to the device handbook - GPIO Feature. Thank you Regards, Chia Ling
