6472 Diskussionen
Set up a NIOS 2 hello world with DE1-SoC rev f with quartus 18.1(elf file failed)
Engineer1981
Einsteiger
522Aufrufe
Good evening, I am compiling for a demo a simple hello world example for DE1-SoC rev f using qsys I have assembled nios2 , onchip and usbjtag, the synthesis is successful and also I have assigned the clk_clk to pin ab27 (location) ... The compilation show me just some warning about that( node was determined to be a clock but was found an associated clock ) . Board is also programmed correctly but if I run the hello world and attack the HW via JTAG USB the result is the message of elf failing. I really do not understand why... Any suggestion? Sorry for the detailed explanation but I'm trying to give a scenario of the problem.
Beschriftungen (1)
3 Antworten
JingyangTeh_Altera
Mitarbeiter
464Aufrufe
Hi
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Back to your issue, what kind of error that you are looking at?
Could you see if the Nios procesor in the jtag chain when you issue the command "jtagconfig -n"?
As a reference there is a how-to to create a NiosII hello world in the link below:
https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset02/nios-ii-hello-world-a10.pdf
Jingyang, Teh
JingyangTeh_Altera
Mitarbeiter
443Aufrufe
Hi
Do you have any follow up question on this case?
Jingyang, Teh
JingyangTeh_Altera
Mitarbeiter
394Aufrufe
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
Antworten
