6473 Discussions
address width above 32 bits are not supported in nios 2
AC1
hi i am using arria 10 development kit. i need to use ddr4 as memory to store the nios application . but if i add external memory interface ip of ddr4 to nios i am getting error as address width above 32 bits are not supported by nios 2. i have attached address span extender. then also i am getting same error
Ahmed_H_Intel1
Hi, The address span extender is the correct way to solve this issue, Please watch the following video to know how to use the address span extender correctly. The example uses a 4GB DDR4 with NIOS II. https://www.youtube.com/watch?v=QmZIZ6VfPCU Regards.
Jacky_chang
hi
The video is private and cannot be viewed without permission.
ggxnd
The video is unavailable. Is there any document/ video on how to use Address span extender ip?
dtopou1
Most of IPs come with reference to documentation.  Check top right cornet for document button.
dtopou1
Just keep in mind that you need to have control slave port enabled at all times otherwise the PD will glitch and think that full DDR address space is exposed to Nios.  Also, check the following post on enabling this IP as memory device.  NIOSII using the FPGA-to-HPS SDRAM Bridge via Address Span Extender
JingyangTeh_Altera
Hi AC1
The correct IP to use is the Address Span Extender IP.
You could find more information in the link below:
https://www.intel.com/content/www/us/en/docs/programmable/683609/21-3/address-span-extender.html
Do you have any more following up question regarding this issue?
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any follow up question on this issue?
Jingyang, Teh
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
