6475 Discussions
System hangs while testing Intel FPGA P-Tile Avalon Memory Mapped (Avalon-MM) IP for PCI Express Design Example User Guide example design
RJoy01
Débutant
2 268 Visites
STRATIX 10DX DEC KIT
Here we have used Intel FPGA P-Tile Avalon Memory Mapped (Avalon-MM) IP for PCI Express Design Example User Guide example design for testing. when we tried to  run the DMA using Example Design Application the system got hanged. We are using QUARTUS PRO 19.4 version.
Test is performed ubuntu18.04LTS
TEST LOG(failed)
vvdn@vvdn-hp:~/Downloads/pcie_ed_software_18Feb2020_1955/software/user/example$ sudo ./intel_fpga_pcie_link_test
Intel FPGA PCIe Link Test
Version 2.0
0: Automatically select a device
1: Manually select a device
> 0
Opened a handle to BAR 0 of a device with BDF 0x100
 0: Link test - 100 writes and reads
 1: Write memory space
 2: Read memory space
 3: Write configuration space
 4: Read configuration space
 5: Change BAR for PIO
 6: Change device
 7: Enable SRIOV
 8: Do a link test for every enabled virtual function
belonging to the current device
 9: Perform DMA
10: Quit program
> 9
Current DMA configurations
Run Read  (card->system)  ? 1
Run Write (system->card)  ? 1
Run Simultaneous      ? 1
Number of dwords/desc : 2048
Number of descriptors : 128
Total length of transfer  : 1024 KiB
 0: Run DMA
 1: Toggle read DMA
 2: Toggle write DMA
 3: Toggle simultaneous DMA
 4: Set the number of dwords per descriptor
 5: Set the number of descriptors per DMA
 6: Return to main menu
> 0
Enter the number of DMA operations to initiate; enter 0 for infinite loop:
>1
0 Compliments
12 Réponses
SengKok_L_Intel
Modérateur
2 092 Visites
Is the links test 100 read & write passed? Could you please reduce the number of descriptors per DMA, or number of Dwords per descriptor to see if this make any difference?
Regards -SK
0 Compliments
RJoy01
Débutant
2 092 Visites
No, the the link test failed .We are able to write to the bars but while we read the whole bar becomes fffffffffffff. After rebooting the host PC we are able to see the written data in the bar.
0 Compliments
RJoy01
Débutant
2 092 Visites
Version 2.0
> 0
 6: Change device
 7: Enable SRIOV
 9: Perform DMA
10: Quit program
> 5
Changing BAR...
Enter BAR number (-1 for none):
> 2
Successfully changed BAR!
 6: Change device
 7: Enable SRIOV
 9: Perform DMA
10: Quit program
> 2
Enter address to read, in hex:
> 0x4
Reading from BDF 0x100 BAR 0x2 offset 0x4..
Read 0
 6: Change device
 7: Enable SRIOV
 9: Perform DMA
10: Quit program
> 1
Enter address to write, in hex:
> 0x4
Enter 32-bit data to write, in hex:
> 0xaabb
Writing 0xaabb at BDF 0x100 BAR 0x2 offset 0x4..
Wrote successfully!
 6: Change device
 7: Enable SRIOV
 9: Perform DMA
10: Quit program
> 2
> 0x4
Read 0xffffffff
 6: Change device
 7: Enable SRIOV
 9: Perform DMA
10: Quit program
> 10
AFTER REBOOT
vvdn@vvdn-hp:~$ sudo md.l f0210004
f0210004: 0000aabb 00000000 00000000 00000000 ................
f0210014: 00000000 00000000 00000000 00000000 ................
f0210024: 00000000 00000000 00000000 00000000 ................
f0210034: 00000000 00000000 00000000 00000000 ................
f0210044: 00000000 00000000 00000000 00000000 ................
f0210054: 00000000 00000000 00000000 00000000 ................
f0210064: 00000000 00000000 00000000 00000000 ................
f0210074: 00000000 00000000 00000000 00000000 ................
f0210084: 00000000 00000000 00000000 00000000 ................
f0210094: 00000000 00000000 00000000 00000000 ................
f02100a4: 00000000 00000000 00000000 00000000 ................
f02100b4: 00000000 00000000 00000000 00000000 ................
f02100c4: 00000000 00000000 00000000 00000000 ................
f02100d4: 00000000 00000000 00000000 00000000 ................
f02100e4: 00000000 00000000 00000000 00000000 ................
f02100f4: 00000000 00000000 00000000 00000000 ................
0 Compliments
RJoy01
Débutant
2 092 Visites
0 Compliments
SengKok_L_Intel
Modérateur
2 092 Visites
I tested v19.4 design example, and I've encountered the same problem as you reported here. Therefore, I will feedback it to the Intel PSG engineering team to resolve the problem. For the moment, I attached the v19.3 sof file for you to perform a quick test, it can run the DMA test without hang, where the link test and memory read/write test are actually not supported here.
Regards -SK
0 Compliments
RJoy01
Débutant
2 092 Visites
By using the SOF file you shared ,DMA operation work properly when i reduce the descriptor count
0 Compliments
SengKok_L_Intel
Modérateur
2 092 Visites
​Please download the v19.3 sof file here.
0 Compliments
SengKok_L_Intel
Modérateur
2 092 Visites
This is glad to know that. Please use v19.3 as the workaround.
Regards -SK
0 Compliments
SengKok_L_Intel
Modérateur
2 092 Visites
For your information, this issue is tentatively targeted to fix in the next version of the Quartus software version release.
0 Compliments
SengKok_L_Intel
Modérateur
2 092 Visites
Hi Romy Joy,
A quick check, is the 19.3 image also working for Memory Read/Write test when changing the BAR# to 2?
Regards -SK
0 Compliments
RJoy01
Débutant
2 092 Visites
yes with this image i am able to perform memory read/ write in bar 2
0 Compliments
SengKok_L_Intel
Modérateur
2 092 Visites
Thanks for the confirmation. Please use v19.3 as a workaround, and this issue will be fixed in the next software version release.
Regards -SK
0 Compliments
Répondre
