6467 ディスカッション
TOF sensor with nios......How?
MLash2
初心者
1,925件の閲覧回数
I need to use a TOF sensor using I2C to comunicate with nios. I used Intel I2C IP but not working. Please help.
0 件の賞賛
8 返答(返信)
Ahmed_H_Intel1
従業員
1,604件の閲覧回数
Hi Mark,
Which TOF sensor you are using? is it an I2C sensor?
MLash2
初心者
1,604件の閲覧回数
I am using vl53l0x which is an I2C sensor. it is working fine with the ARDUINO. please help to teach me how to use it with the FPGA.
Ahmed_H_Intel1
従業員
1,604件の閲覧回数
MLash2
初心者
1,604件の閲覧回数
Thanks a lot @AhmedH_Intel​
I think this help to start my business.
MLash2
初心者
1,604件の閲覧回数
I see that I can use the DMA with the sensor, correct?
Ahmed_H_Intel1
従業員
1,604件の閲覧回数
Yes, you can use the DMA to stream the sensor data for example or to update a memory with the sensor data.
MLash2
初心者
1,604件の閲覧回数
Thanks a lot, I will check the DMA.
Ahmed_H_Intel1
従業員
1,604件の閲覧回数
You are welcome.
返信
