hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
6241 Discussions
Type error near ; current type std_logic_vector; expected type std_ulogic error in vhdl. How to solve this error
Spk00
sstrell
Can you post your code?
#iwork4intel
AnandRaj_S_Intel
Hi Sisira,
The error may be due to a mismatch in vector size or operator misinterpretation.
Share your code.
Anand
Spk00
This is my code
Library ieee;
Use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity ttcaam is
port(clk:in std_logic);
end ttcaam;
architecture Behavioral of ttcaam is
type mem0 is array(0 to 5) of std_logic_vector(0 to 5);
signal mem:mem0;
type mem1 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_1:mem1;
type mem2 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_2:mem2;
type mem3 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_3:mem3;
type mem4 is array (0 to 5) of std_logic_vector(0 to 5);
signal mem_4:mem4;
signal q1:std_logic_vector(0 to 5);
signal q2:std_logic_vector(0 to 5);
signal q3:std_logic_vector(0 to 5);
signal q4:std_logic_vector(0 to 5);
signal q5:std_logic_vector(0 to 5);
signal q6:std_logic_vector(0 to 5);
constant r:std_logic_vector(0 to 1):="00";
constant s:std_logic_vector(0 to 1):="01";
constant t:std_logic_vector(0 to 1):="10";
constant u:std_logic_vector(0 to 1):="11";
constant v:std_logic_vector(0 to 1):="-0";
constant w:std_logic_vector(0 to 1):="-1";
constant y:std_logic_vector(0 to 1):="0-";
constant z:std_logic_vector(0 to 1):="1-";
signal q:std_logic_vector(0 to 5);
signal i:integer ;
signal j:integer:=0;
signal a:integer;
signal b:integer;
signal c:integer;
signal d:integer;
signal e:integer;
begin
q1<="001001";
q2<="11-100";
q3<="-10010";
q4<="100-11";
q5<="0-01-1";
q6<="-10001";
process(clk,q(1),q(3))
begin
if(i=0) then
mem(i)<=q1;
i<=i+1;
elsif(i=1) then
mem(i)<=q2;
i<=i+1;
elsif(i=2) then
mem(i)<=q3;
i<=i+1;
elsif(i=3) then
mem(i)<=q4;
i<=i+1;
elsif(i=4) then
mem(i)<=q5;
i<=i+1;
elsif(i=5) then
mem(i)<=q6;
i<=i+1;
else
if(j<=5) then
q<=mem(j);
case q(1) and q(3) is
when r=>
e<=e+1;
  mem_1(a)<=q;
  a<=a+1;
when s=>
e<=e+1;
  mem_2(b)<=q;
  b<=b+1;
when t=>
e<=e+1;
  mem_3(c)<=q;
  c<=c+1;
  when u=>
e<=e+1;
  mem_4(d)<=q;
  d<=d+1;
when v=>
  mem_1(a)<=q;
  a<=a+1;
  mem_3(c)<=(q(0),'1',q(2),q(3),q(4),q(5));
  c<=c+1;
  when w=>
  mem_2(b)<=(q(0),'0',q(2),q(3),q(4),q(5));
  b<=b+1;
  mem_4(d)<=(q(0),'1',q(2),q(3),q(4),q(5));
  d<=d+1;
 when y=>
  mem_1(a)<=(q(0),q(1),q(2),'0',q(4),q(5));
  a<=a+1;
  mem_2(b)<=(q(0),q(1),q(2),'1',q(4),q(5));
  b<=b+1;
 when z=>
  mem_3(c)<=(q(0),q(1),q(2),'0',q(4),q(5));
  c<=c+1;
  mem_4(d)<=(q(0),q(1),q(2),'1',q(4),q(5));
  d<=d+1;
  end case;
j<=j+1;
end if;
end if;
end process;
end;
sstrell
Without line numbers or a fixed width font, it's a little tricky to figure out what's going on here, but I do see an errant space:
signal i:integer ;
I don't know if that's the issue. Does the tool say which line number(s) have issues?
#iwork4intel
Spk00
Error is inside case statement.
ie;Type error near r,s,t,u,v,w,y,z ; current type std_logic_vector; expected type std_ulogic error
AnandRaj_S_Intel
Hi Sisira,
  1. At line 85, you have used the logical operator "and" which is defined for BIT and BOOLEAN types.
  2. At 86 you are expecting 2bits for state "r"
VHDL concatenate operator is an ampersand (&). It can be used to combine two or more items together.
 Example pad 0 in MSB.
case( 0 & (q(1) and q(3)) is
or case(q(1) & q(3)) is
Anand
Spk00
I have checked both the cases . But again I got an error that is " Near case_expression ; 6 visible identifiers match here"
AnandRaj_S_Intel
Okay,
Add below lines at the appropriate location and check
signal x:std_logic_vector(0 to 1);
x<=q(1)&q(3);
case (x) is
when others =>
Anand
Spk00
