6459 Discussions
UART functionality in altera max II EMP240 CPLD
srimathi
Hi everyone,
I'm currently working on implementing UART communication on an Altera MAX II CPLD using Verilog. As I'm still learning, I would really appreciate it if anyone could share UART transmitter and receiver Verilog code. Thanks in advance.
KennyTan_Altera
I'll provide you with synthesizable UART transmitter and receiver Verilog code suitable for Altera MAX II CPLD implementation. But you will need to write your testbench to test out the code:
## UART Transmitter
```verilog
module uart_tx #(
  parameter CLOCK_FREQ = 50000000, // 50 MHz clock
  parameter BAUD_RATE = 9600    // 9600 baud
  input clk,
  input rst_n,
  input [7:0] tx_data,
  input tx_start,
  output reg tx,
  output reg tx_busy
localparam BAUD_TICKS = CLOCK_FREQ / BAUD_RATE;
localparam COUNTER_WIDTH = $clog2(BAUD_TICKS);
reg [COUNTER_WIDTH-1:0] baud_counter;
reg [3:0] bit_counter;
reg [9:0] tx_shift_reg; // Start bit + 8 data bits + Stop bit
reg baud_tick;
// Baud rate generator
always @(posedge clk or negedge rst_n) begin
  if (!rst_n) begin
    baud_counter <= 0;
    baud_tick <= 1'b0;
  end else begin
    if (baud_counter == BAUD_TICKS - 1) begin
      baud_counter <= 0;
      baud_tick <= 1'b1;
    end else begin
      baud_counter <= baud_counter + 1;
      baud_tick <= 1'b0;
    end
  end
end
// UART transmitter state machine
  if (!rst_n) begin
    tx <= 1'b1;      // Idle high
    tx_busy <= 1'b0;
    bit_counter <= 0;
    tx_shift_reg <= 10'h3FF; // All ones (idle)
  end else begin
    if (tx_start && !tx_busy) begin
      tx_shift_reg <= {1'b1, tx_data, 1'b0}; // Stop + Data + Start
      tx_busy <= 1'b1;
      bit_counter <= 0;
    end else if (tx_busy && baud_tick) begin
      tx <= tx_shift_reg[0];
      tx_shift_reg <= {1'b1, tx_shift_reg[9:1]};
      if (bit_counter == 9) begin
        tx_busy <= 1'b0;
        bit_counter <= 0;
      end else begin
        bit_counter <= bit_counter + 1;
      end
    end
  end
end
endmodule
## UART Receiver
```verilog
module uart_rx #(
  input clk,
  input rst_n,
  input rx,
  output reg [7:0] rx_data,
  output reg rx_valid
localparam HALF_BAUD_TICKS = BAUD_TICKS / 2;
reg [7:0] rx_shift_reg;
reg baud_tick;
reg rx_sync1, rx_sync2; // Synchronizer for rx input
// Input synchronizer
  if (!rst_n) begin
    rx_sync1 <= 1'b1;
    rx_sync2 <= 1'b1;
  end else begin
    rx_sync1 <= rx;
    rx_sync2 <= rx_sync1;
  end
end
// State machine states
localparam IDLE = 2'b00;
localparam START = 2'b01;
localparam DATA = 2'b10;
localparam STOP = 2'b11;
reg [1:0] state;
// Baud rate counter
  if (!rst_n) begin
    baud_counter <= 0;
    baud_tick <= 1'b0;
  end else begin
    if (state == IDLE) begin
      baud_counter <= 0;
      baud_tick <= 1'b0;
    end else if (baud_counter == BAUD_TICKS - 1) begin
      baud_counter <= 0;
      baud_tick <= 1'b1;
    end else begin
      baud_tick <= 1'b0;
    end
  end
end
// UART receiver state machine
  if (!rst_n) begin
    state <= IDLE;
    bit_counter <= 0;
    rx_shift_reg <= 0;
    rx_data <= 0;
    rx_valid <= 1'b0;
  end else begin
    rx_valid <= 1'b0; // Default: no valid data
    case (state)
      IDLE: begin
        if (!rx_sync2) begin // Start bit detected
          state <= START;
          baud_counter <= 0;
        end
      end
      START: begin
        if (baud_counter == HALF_BAUD_TICKS) begin
          if (!rx_sync2) begin // Confirm start bit
            state <= DATA;
            bit_counter <= 0;
            baud_counter <= 0;
          end else begin
            state <= IDLE; // False start bit
          end
        end
      end
      DATA: begin
        if (baud_tick) begin
          rx_shift_reg <= {rx_sync2, rx_shift_reg[7:1]};
          if (bit_counter == 7) begin
            state <= STOP;
            bit_counter <= 0;
          end else begin
          end
        end
      end
      STOP: begin
          if (rx_sync2) begin // Valid stop bit
            rx_data <= rx_shift_reg;
            rx_valid <= 1'b1;
          end
          state <= IDLE;
        end
      end
    endcase
  end
end
endmodule
## Top-Level UART Module
```verilog
module uart_top #(
  input clk,
  input rst_n,
  // TX interface
  input tx_start,
  output tx_busy,
  output uart_tx,
  // RX interface
  input uart_rx,
  output [7:0] rx_data,
  output rx_valid
uart_tx #(
  .CLOCK_FREQ(CLOCK_FREQ),
  .BAUD_RATE(BAUD_RATE)
) tx_inst (
  .clk(clk),
  .rst_n(rst_n),
  .tx_data(tx_data),
  .tx_start(tx_start),
  .tx(uart_tx),
  .tx_busy(tx_busy)
uart_rx #(
) rx_inst (
  .clk(clk),
  .rst_n(rst_n),
  .rx(uart_rx),
  .rx_data(rx_data),
  .rx_valid(rx_valid)
endmodule
## Key Features
- **Parameterizable**: Clock frequency and baud rate can be configured
- **Synchronous Design**: Uses proper clock domain design suitable for MAX II
- **Input Synchronization**: RX input is properly synchronized to avoid metastability
- **Standard UART Protocol**: 1 start bit, 8 data bits, 1 stop bit, no parity
- **Handshaking**: TX has busy signal, RX has valid signal
## Usage Example
```verilog
// Instantiate in your top-level design
uart_top #(
  .CLOCK_FREQ(50000000), // 50 MHz
  .BAUD_RATE(115200)   // 115200 baud
) uart_inst (
  .clk(clk_50mhz),
  .rst_n(reset_n),
  .tx_data(data_to_send),
  .tx_start(send_enable),
  .tx_busy(uart_busy),
  .uart_tx(uart_tx_pin),
  .uart_rx(uart_rx_pin),
  .rx_data(received_data),
  .rx_valid(data_ready)
FvM
compiling the Verilog uart code, I see multiple drivers for baud_counter in uart_rx module. Can be fixed by merging Baud rate counter and UART receiver state machine always blocks.
Frank
srimathi
Is that code is working for you, I barely see any waveform on the tx line.
KennyTan_Altera
How about try the below:
module uart_rx #(
  input clk,
  input rst_n,
  input rx,
  output reg rx_valid
reg baud_tick;
  if (!rst_n) begin
    rx_sync1 <= 1'b1;
    rx_sync2 <= 1'b1;
  end else begin
    rx_sync1 <= rx;
  end
end
reg [1:0] state;
// Combined baud counter and UART receiver state machine
  if (!rst_n) begin
    state <= IDLE;
    bit_counter <= 0;
    rx_shift_reg <= 0;
    rx_data <= 0;
    rx_valid <= 1'b0;
    baud_counter <= 0;
    baud_tick <= 1'b0;
  end else begin
    baud_tick <= 1'b0; // Default: no baud tick
    case (state)
      IDLE: begin
        baud_counter <= 0;
          state <= START;
          baud_counter <= 0;
        end
      end
      START: begin
            state <= DATA;
            bit_counter <= 0;
            baud_counter <= 0;
          end else begin
          end
        end else begin
        end
      end
      DATA: begin
          baud_counter <= 0;
          baud_tick <= 1'b1;
            state <= STOP;
            bit_counter <= 0;
          end else begin
          end
        end else begin
        end
      end
      STOP: begin
          baud_counter <= 0;
          baud_tick <= 1'b1;
            rx_valid <= 1'b1;
          end
          state <= IDLE;
        end else begin
        end
      end
    endcase
  end
end
endmodule
You're correct! The issue is that both the baud rate counter logic and the state machine are trying to drive the `baud_counter` signal, creating multiple drivers. Here's the fixed UART receiver code with the two always blocks merged:
## Fixed UART Receiver Code
```verilog
module uart_rx #(
  input clk,
  input rst_n,
  input rx,
  output reg rx_valid
reg baud_tick;
  if (!rst_n) begin
    rx_sync1 <= 1'b1;
    rx_sync2 <= 1'b1;
  end else begin
    rx_sync1 <= rx;
  end
end
reg [1:0] state;
  if (!rst_n) begin
    state <= IDLE;
    bit_counter <= 0;
    rx_shift_reg <= 0;
    rx_data <= 0;
    rx_valid <= 1'b0;
    baud_counter <= 0;
    baud_tick <= 1'b0;
  end else begin
    case (state)
      IDLE: begin
        baud_counter <= 0;
          state <= START;
          baud_counter <= 0;
        end
      end
      START: begin
            state <= DATA;
            bit_counter <= 0;
            baud_counter <= 0;
          end else begin
          end
        end else begin
        end
      end
      DATA: begin
          baud_counter <= 0;
          baud_tick <= 1'b1;
            state <= STOP;
            bit_counter <= 0;
          end else begin
          end
        end else begin
        end
      end
      STOP: begin
          baud_counter <= 0;
          baud_tick <= 1'b1;
            rx_valid <= 1'b1;
          end
          state <= IDLE;
        end else begin
        end
      end
    endcase
  end
end
endmodule
## Key Changes Made
1. **Merged Always Blocks**: Combined the separate baud counter and state machine always blocks into a single always block to eliminate multiple drivers for `baud_counter`.
2. **State-Specific Counter Logic**: The baud counter now resets and increments based on the current state:
  - **IDLE**: Counter is reset to 0
  - **START**: Counter increments until half baud period
  - **DATA/STOP**: Counter increments until full baud period, then resets
3. **Simplified Baud Tick Generation**: The `baud_tick` signal is now generated inline with the counter logic rather than in a separate process.
## Complete Updated Top-Level Module
The UART transmitter and top-level module remain the same. Just replace the `uart_rx` module with the fixed version above.
KennyTan_Altera
See if the below testbench will help you also?
`timescale 1ns/1ps
module tb_uart_top;
  // Parameters
  parameter CLOCK_FREQ = 50000000; // 50 MHz
  parameter BAUD_RATE = 115200;  // 115200 baud for faster simulation
  parameter CLK_PERIOD = 20.0;   // 50 MHz = 20ns period
  parameter BIT_PERIOD = 1000000000.0 / BAUD_RATE; // Bit period in ns
  // DUT signals
  reg clk;
  reg rst_n;
  // TX interface
  reg [7:0] tx_data;
  reg tx_start;
  wire tx_busy;
  wire uart_tx;
  // RX interface
  reg uart_rx;
  wire [7:0] rx_data;
  wire rx_valid;
  // Test variables
  reg [7:0] test_data_queue[$];
  reg [7:0] received_data_queue[$];
  integer test_count = 0;
  integer error_count = 0;
  // Clock generation
  initial begin
    clk = 0;
    forever #(CLK_PERIOD/2) clk = ~clk;
  end
  // DUT instantiation
  uart_top #(
  ) dut (
    .clk(clk),
    .rst_n(rst_n),
    .tx_data(tx_data),
    .tx_busy(tx_busy),
    .uart_tx(uart_tx),
    .uart_rx(uart_rx),
    .rx_data(rx_data),
    .rx_valid(rx_valid)
  // Task to send a byte via UART TX
  task send_byte(input [7:0] data);
    begin
      @(posedge clk);
      while (tx_busy) @(posedge clk); // Wait for TX to be ready
      tx_data = data;
      tx_start = 1'b1;
      @(posedge clk);
      tx_start = 1'b0;
      test_data_queue.push_back(data);
      $display("Time %0t: Sending byte 0x%02h", $time, data);
      @(posedge clk);
      while (tx_busy) @(posedge clk); // Wait for transmission to complete
    end
  endtask
  // Task to simulate receiving a byte via UART RX
  task receive_byte(input [7:0] data);
    integer i;
    begin
      $display("Time %0t: Simulating RX byte 0x%02h", $time, data);
      // Send start bit (0)
      uart_rx = 1'b0;
      #(BIT_PERIOD);
      // Send 8 data bits (LSB first)
      for (i = 0; i < 8; i = i + 1) begin
        uart_rx = data[i];
        #(BIT_PERIOD);
      end
      // Send stop bit (1)
      uart_rx = 1'b1;
      #(BIT_PERIOD);
    end
  endtask
  // Monitor RX valid data
  always @(posedge clk) begin
    if (rx_valid) begin
      received_data_queue.push_back(rx_data);
      $display("Time %0t: Received byte 0x%02h", $time, rx_data);
    end
  end
  // Task to verify received data
  task verify_received_data();
    reg [7:0] expected, actual;
    begin
      while (test_data_queue.size() > 0 && received_data_queue.size() > 0) begin
        expected = test_data_queue.pop_front();
        actual = received_data_queue.pop_front();
        if (expected == actual) begin
          $display("✓ PASS: Expected 0x%02h, Got 0x%02h", expected, actual);
        end else begin
          $display("✗ FAIL: Expected 0x%02h, Got 0x%02h", expected, actual);
          error_count = error_count + 1;
        end
        test_count = test_count + 1;
      end
    end
  endtask
  // Loopback connection for self-test
  always @(*) begin
    uart_rx = uart_tx;
  end
  // Main test sequence
  initial begin
    // Initialize signals
    rst_n = 1'b0;
    tx_data = 8'h00;
    tx_start = 1'b0;
    uart_rx = 1'b1; // UART idle state
    $display("=== UART Testbench Starting ===");
    $display("Clock Frequency: %0d Hz", CLOCK_FREQ);
    $display("Baud Rate: %0d", BAUD_RATE);
    $display("Bit Period: %0.2f ns", BIT_PERIOD);
    // Reset sequence
    #(CLK_PERIOD * 10);
    rst_n = 1'b1;
    #(CLK_PERIOD * 10);
    // Test 1: Basic loopback test
    $display("\n=== Test 1: Basic Loopback Test ===");
    send_byte(8'h55); // Alternating pattern
    send_byte(8'hAA); // Inverse alternating pattern
    send_byte(8'h00); // All zeros
    send_byte(8'hFF); // All ones
    // Wait for data to be received
    #(BIT_PERIOD * 20);
    // Test 2: ASCII characters
    $display("\n=== Test 2: ASCII Character Test ===");
    send_byte(8'h48); // 'H'
    send_byte(8'h65); // 'e'
    send_byte(8'h6C); // 'l'
    send_byte(8'h6F); // 'o'
    send_byte(8'h20); // ' '
    send_byte(8'h55); // 'U'
    send_byte(8'h41); // 'A'
    send_byte(8'h52); // 'R'
    send_byte(8'h54); // 'T'
    #(BIT_PERIOD * 30);
    // Test 3: Back-to-back transmission
    $display("\n=== Test 3: Back-to-Back Transmission ===");
    for (int i = 0; i < 16; i++) begin
      send_byte(i);
    end
    // Wait for all data to be received
    #(BIT_PERIOD * 50);
    // Test 4: RX-only test (disconnect loopback)
    $display("\n=== Test 4: RX-Only Test ===");
    // Disconnect loopback for manual RX testing
    force uart_rx = 1'b1;
    #(CLK_PERIOD * 5);
    // Manually send some bytes to RX
    release uart_rx;
    receive_byte(8'hA5);
    receive_byte(8'h5A);
    receive_byte(8'h96);
    // Wait and check
    #(BIT_PERIOD * 10);
    // Final results
    #(BIT_PERIOD * 20);
    $display("\n=== Test Results ===");
    $display("Total tests: %0d", test_count + 3); // +3 for RX-only tests
    $display("Errors: %0d", error_count);
    if (error_count == 0) begin
      $display("✓ ALL TESTS PASSED!");
    end else begin
      $display("✗ %0d TESTS FAILED!", error_count);
    end
    $display("\n=== UART Testbench Complete ===");
    $finish;
  end
  // Timeout watchdog
  initial begin
    #(BIT_PERIOD * 1000); // Long timeout
    $display("ERROR: Testbench timeout!");
    $finish;
  end
  // Optional: Dump waveforms
  initial begin
    $dumpfile("uart_tb.vcd");
    $dumpvars(0, tb_uart_top);
  end
endmodule
KennyTan_Altera
Do you have any further questions? If not, we’ll go ahead and close this thread.
By the way, please note that we do not provide support for customized code. The code shared above is based on open-source examples and is provided as-is.
KennyTan_Altera
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
