6468 Discussions
Unable to install BSP using aocl install
Raghuttam
I have a BittWare A10PL4 board containing Arria 10 chip on it. I received the BSP from BittWare and tried to install it using `aocl install` and this is what I received.
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n]
aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege
Install the FCD file to /opt/Intel/OpenCL/Boards
[sudo] password for raghuttam:
aocl install: Adding the board package /home/raghuttam/experimental/a10pl4_bsp to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /home/raghuttam/experimental/a10pl4_bsp/linux64/libexec
/home/raghuttam/experimental/a10pl4_bsp/linux64/libexec/install: 9: [: aclpci_a10pl4_drv: unexpected operator
Looking for kernel source files in /lib/modules/6.8.0-52-generic/build
Using kernel source files from  /lib/modules/6.8.0-52-generic/build
Building driver for BSP with name a10pl4
make: Entering directory '/usr/src/linux-headers-6.8.0-52-generic'
  CC [M]  /tmp/opencl_driver_Z124LQ/aclpci_queue.o
In file included from /tmp/opencl_driver_Z124LQ/aclpci.h:85,
                 from /tmp/opencl_driver_Z124LQ/aclpci_queue.c:56:
/tmp/opencl_driver_Z124LQ/aclpci_dma.h:204:18: error: field ?m_us_dma_start_time? has incomplete type
  204 |   struct timeval m_us_dma_start_time;
/tmp/opencl_driver_Z124LQ/aclpci_queue.c:104:7: warning: no previous prototype for ?queue_addr? [-Wmissing-prototypes]
  104 | void *queue_addr (struct queue *q, unsigned int offset) {
/tmp/opencl_driver_Z124LQ/aclpci_queue.c:111:14: warning: no previous prototype for ?fast_mod? [-Wmissing-prototypes]
  111 | unsigned int fast_mod (unsigned int val, unsigned int size) {
make[2]: *** [scripts/Makefile.build:243: /tmp/opencl_driver_Z124LQ/aclpci_queue.o] Error 1
make[1]: *** [/usr/src/linux-headers-6.8.0-52-generic/Makefile:1925: /tmp/opencl_driver_Z124LQ] Error 2
make: *** [Makefile:240: __sub-make] Error 2
make: Leaving directory '/usr/src/linux-headers-6.8.0-52-generic'
aocl install: failed.
aocl install: Removing FCD
aocl install: Removing the board package /home/raghuttam/experimental/a10pl4_bsp from the list of installed packages
BoonBengT_Altera
Hi @Raghuttam,
Thank you for posting in Intel community forum and hope all is well.
Unfortunately as the BSP are coming from BittWare and we have limited understanding and access to that, hence it limit us from further checking. However we would try our best to look into the situation, but as the final resources, you may need to contact BittWare support.
Would recommend the following:
- Could you run a aocl diagnose to check on the OpenCL platform setup/settings just to be sure.
- Perhaps also uninstalling the mention bsp just to get a clear start
- Is this limited to just to BSP or were there other BSP successfully installed?
Best Wishes
BB
BoonBengT_Altera
Hi @Raghuttam,
Good day, just following up on the previous clarification.
By any chances did you managed to look into it?
Hope to hear from you soon.
Best Wishes
BB
BoonBengT_Altera
Hi @Raghuttam,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
