6474 Discussions
Updating Yocto from Nanbield to Scarthgap Error
james57
Hi there,
I am currently looking to update the version of linux I am building for from the previous nanbield-4.3.4 on GSRD to the new lts scarthgap-5.0.2.
I have run the commands from the GSRD to do so a few times and contiune to run into the same error continuously. After starting the bitbake core-minimal-image command the bitbake process starts to parse recipes, when it fails due to an error.
I will post a screenshot of the error it encounters.
The issue is due to the following .bb file, openssh_9.6p1.bb located in gsrd_socfpga/poky/meta/recipes-connectivity/openssh
The .bb file calls for fix-potential-signed-overflow-in-pointer-arithmatic.patch, but this file does not exist in the current version of scarthgap-5.0.2, or in the master branch.
scarthgap:
https://github.com/openembedded/openembedded-core/tree/scarthgap/meta/recipes-connectivity/openssh/openssh/fix-potential-signed-overflow-in-pointer-arithmatic.patch
nanbield:
https://github.com/openembedded/openembedded-core/blob/nanbield/meta/recipes-connectivity/openssh/openssh/fix-potential-signed-overflow-in-pointer-arithmatic.patch
I attempted to modify the .bb file to not call the SRC_URI of the needed .patch file but was unable to find the correct location of the call.
The file still exists in the older nanbield version, and yocto builds when I insert the file into the correct location however this is a lazy fix as I am still counting on outdated versions and would like to change to the new lts.
Am I missing something or was this overlooked?
Cheers,
James
james57
Hi
This was overlooked in the July 26th revisions of the Rocketboards builds I was referencing, luckily this issue was addressed on the 8th and 9th of August in revisions 78 and 79 for the Agilex I-Series SoC respectively.
https://www.rocketboards.org/foswiki/diff/Documentation/AgilexSoCGSRDSIAGI027?oldrev=78&newrev=79
Cheers,
James
james57
Hi
Cheers,
James
