6472 Discussions
Verifying a System Design Created by Quartus Platform Designer
AJung123
I recently developed a platform which connected the HPS of a Stratix 10 to the DMA controller. Is there a way to verify this design in simulation rather than putting this in the board and testing it? I want to test that when issuing memory transactions through the driver, it will output the correct results similarly to this design: http://blog.reds.ch/?p=835
EBERLAZARE_I_Intel
You could check the video below regarding the mSGDMA usage in Platform Designer with explanations to start with.
https://www.youtube.com/watch?v=iaRkjkpMBH8
At the end of the video it demonstrates the checking of data streaming using the In-System Sources Probe.
Regards.
