can't config Arria 10
scong4
I use a Arria 10 10AS048H4F34E3SG, set MSEL[2:0] to 011,VCC and VCCPGM = 1.8V.
I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high again . The configuration is fault , How can I find the problem ?
Shiping
ShafiqY_Intel
Hi scong4,
Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM?
Noted: the nSTATUS signal low to indicate a configuration error.
scong4
Thank you for your reply! I send my configration circuit to you . The nSATUS pin connects to a 10Kohm resistor . And the power up is 0.9v->1.0v->1.8v . Thanks shiping cong Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks WolfGang (Intel) Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks View/Answer or reply to this email Replying to scong4 (Customer) asked a question. Wednesday, 2020年1月8日 AM8:43 can't config Arria 10 I use a Arria 10 10AS048H4F34E3SG, set MSEL[2:0] to 011,VCC and VCCPGM = 1.8V. I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high again . The configuration is fault , How can I find the problem ? Regards Shiping WolfGang (Intel) Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks Thursday, 2020年1月9日 PM1:40 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]
ShafiqY_Intel
Hi scong4,
I did not get your configration circuit.
where you send it? Is it to my private message or in this thread?
Regards.
WolfGang
scong4
This is the circuit.
ShafiqY_Intel
Hi scong4,
May I know the connection of pins TCK, TDI, TDO? (no information in above picture)
Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2)
besides, do you used .jic file to program the FPGA?
When you convert to .jic, did you TICK both of this option?
Thanks..
scong4
Hi WolfGang My flash device is EPCQL256F24IN. GND--| 1K | TCK -- 1 2 -- GND TDO -- 3 4 -- +1.8V TMS -- 5 6 -- +1.8V -- 7 8 -- TDI -- 9 10 -- GND | 1K | +1.8V This board modified from a old design , no change with the FPGA ciruit . So I use the same data file with the old design and write the data to the flash. I think the data is correct. Thanks WolfGang (Intel) Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. View/Answer or reply to this email Replying to can't config Arria 10 scong4 (Customer) Thursday, 2020年1月9日 PM3:10 [Image placeholder for fpgaconfig] fpgaconfig This is the circuit. WolfGang (Intel) Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. Thursday, 2020年1月9日 PM4:12 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]
ShafiqY_Intel
How about this "When you convert to .jic, did you TICK both of this option?"
cheers
scong4
I didn't do this step , I use a flash image write the configuration data directly . Thanks
ShafiqY_Intel
What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2)
scong4
My flash image is binary file I try to read data from my config flash by programmer and usb blaster , the examine check box is gray and can't be check. What the problem ? How can read data from the flash ? Thanks WolfGang (Intel) What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2) View/Answer or reply to this email Replying to can't config Arria 10 WolfGang (Intel) Thursday, 2020年1月9日 PM4:12 Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. scong4 (Customer) I didn't do this step , I use a flash image write the configuration data directly . Thanks Thursday, 2020年1月9日 PM6:29 WolfGang (Intel) What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2) Monday, 2020年1月13日 PM1:08 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]
ShafiqY_Intel
Hi scong4,
What type of binary file you used?
can you screenshot and send it here?
scong4
It's a HEX data . Here is the screen shot. WolfGang (Intel) Hi scong4, What type of binary file you used? the examine check box is gray and can't be check can you screenshot and send it here? View/Answer or reply to this email Replying to can't config Arria 10 WolfGang (Intel) Thursday, 2020年1月9日 PM4:12 Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. scong4 (Customer) My flash image is binary file I try to read data from my config flash by programmer and usb blaster , the examine check box is gray and can't be check. What the problem ? How can read data from the flash ? Thanks WolfGang (Intel) What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2) View/Answer or reply to this email Replying to can't config Arria 10 WolfGang (Intel) Thursday, 2020年1月9日 PM4:12 Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. scong4 (Customer) I didn't do this step , I use a flash image write the configuration data directly . Thanks Thursday, 2020年1月9日 PM6:29 WolfGang (Intel) What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2) Monday, 2020年1月13日 PM1:08 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums] Monday, 2020年1月13日 PM8:01 WolfGang (Intel) Hi scong4, What type of binary file you used? the examine check box is gray and can't be check can you screenshot and send it here? Tuesday, 2020年1月14日 PM2:00 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]
ShafiqY_Intel
Hi scong4,
It's a HEX data .
is it .hex file?
can you resend the screenshot? I can't see the photo.
scong4
The data is a flash Image , it include a FPGA config data and Linux file sysytem。 We write the two data to the Flash first and then read from the flash, save the read data to be a binary file. Next step read the binary file and write to the config flash. Hi scong4, It's a HEX data . is it .hex file? Here is the screen shot. can you resend the screenshot? I can't see the photo. Thanks WolfGang (Intel) Hi scong4, It's a HEX data . is it .hex file? Here is the screen shot. can you resend the screenshot? I can't see the photo. Thanks View/Answer or reply to this email Replying to can't config Arria 10 WolfGang (Intel) Thursday, 2020年1月9日 PM4:12 Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. scong4 (Customer) It's a HEX data . Here is the screen shot. WolfGang (Intel) Hi scong4, What type of binary file you used? the examine check box is gray and can't be check can you screenshot and send it here? View/Answer or reply to this email Replying to can't config Arria 10 WolfGang (Intel) Thursday, 2020年1月9日 PM4:12 Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. scong4 (Customer) My flash image is binary file I try to read data from my config flash by programmer and usb blaster , the examine check box is gray and can't be check. What the problem ? How can read data from the flash ? Thanks WolfGang (Intel) What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2) View/Answer or reply to this email Replying to can't config Arria 10 WolfGang (Intel) Thursday, 2020年1月9日 PM4:12 Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. scong4 (Customer) I didn't do this step , I use a flash image write the configuration data directly . Thanks Thursday, 2020年1月9日 PM6:29 WolfGang (Intel) What is your flash image data type you are using? (i.e .rpd file, .jic file, .pof file or etc2) Monday, 2020年1月13日 PM1:08 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums] Monday, 2020年1月13日 PM8:01 WolfGang (Intel) Hi scong4, What type of binary file you used? the examine check box is gray and can't be check can you screenshot and send it here? Tuesday, 2020年1月14日 PM2:00 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums] Tuesday, 2020年1月14日 PM2:14 WolfGang (Intel) Hi scong4, It's a HEX data . is it .hex file? Here is the screen shot. can you resend the screenshot? I can't see the photo. Thanks Tuesday, 2020年1月14日 PM4:27 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as 300002477859@intel.com.isvc. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]
ShafiqY_Intel
Yes, I know you are using binary file. But, what is your binary file type? .bin or .rbf or anything?
As for nConfig & nStatus, did you external 10-kΩ pull-up resistor to VCCPGM?
