6474 Discussions
how can we start quartus ii std version in linux version by command..
gsing54
how can we start quartus ii std version in linux version by command window ..
AnandRaj_S_Intel
Hi Gurunam,
To launch quartus, open a terminal navigate to Quartus/bin directory and simply type quartus and enter.
or
Adding the path of your quartus in ~/.bashrc
export PATH=$PATH:<>/quartus/bin
open a terminal and simply type quartus.
Anand
gsing54
quartus: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
we are getting that error when we start the quartus ii std ver
  1. we were install the quartus ii 19.1 ver linux then we open the dir Quartus/bin then run quartus script
  2. but it showing the above error ...
AnandRaj_S_Intel
Hi gurunam,
Please go through similar case below.
https://forums.intel.com/s/question/0D50P00003yyNvVSAU/quartus-cant-find-shared-library
Can i know which Linux flavor are you using?
Anand
gsing54
Hello Anand
we using the linux centos 8.....
NAME="CentOS Linux"
VERSION="8 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="8"
PLATFORM_ID="platform:el8"
PRETTY_NAME="CentOS Linux 8 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:8"
HOME_URL="https://www.centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
Gurunam
AnandRaj_S_Intel
Hi Guru,
I suspect OS, Centos is not supported for Quartus. Please use any other Linux flavor as per Quartus requirements from blow link.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html
Anand
gsing54
hello,
can we use quartus pro license file in quartus std edition license ver 19.1.
AnandRaj_S_Intel
Hi Gurunam,
Kindly open new case, Your question deviate from subject of the case.
However
 Intel Quartus Prime Pro Edition software seat licenses include licenses for the Intel Quartus Prime Standard Edition software. So you can use.
Anand
gsing54
Hello Anand,
I just want work on cyclone v soc fpga so as per your previous reply its is not available in Quartus pro ver then you suggest me to use Quartus standard ver . Now i have Quartus standard ver and in that i am using quartus pro ver license file then on runing program it showing that you do not have valid license file . I did not understand .
so please tell me how can i start with cyclone v .
Gurunam
AnandRaj_S_Intel
Please contact FAE for further support.
reference
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/licensing.html
