Hi
I want to assign HPS_CLK1 as system clock , but I can't find it from pin list in the Pin Planner.
May I know which Quartus Version you are working on?
Are you using your own design or from an example designs?
I will check the design out. Is the design your own or you get it anywhere from the web?
Noted that.
If you cant find it on the Pin Planner, you may need to recompile your design in Qsys/Platform Designer.
If you are looking for more of our example design, you may find it here:
