problam with modelsim
MShim18
the program supposed to count the number of '1' in a given 32bit input
library IEEE;
use IEEE.std_logic_1164.all;
entity one_cnt is
port( serial_bit_input : in std_logic_vector (31 downto 0);
result   : out integer range 0 to 32) ;
end;
architecture behave of one_cnt is
signal cnt : integer range 0 to 32;
begin
process(serial_bit_input)
begin
cnt<=0;
count_loop : for i in 31 downto 0 loop
if serial_bit_input(i)='1' then
cnt<=cnt+1;
end if;
end loop count_loop;
result<=cnt;
end process;
end architecture;
as you can see :
* Fatal: (vsim-3807) Types do not match between component and entity for port "result"
what sould i do?
SyafieqS
Hi Matan,
From what I see, you are using different package other that std logic between component and entity declaration result in mismatch type. Try to change you code in your testbench in component port same to std logic package
entity one_cnt is
Refer to link below as it same case with you for reference
https://forums.intel.com/s/question/0D50P00003yyQfgSAE/modelsim-types-do-not-match?language=en_US
