5701 Discussions
recommend Stratix II GX EP2SGX60EF1152C5N replaced parts
EP2SGX60EF1152C5N
Stratix II GX EP2SGX60EF1152C5N end of life. Can you please recommend a alternative part? Below points are preferred. 1. FPGA code change is small. 2. Pin-to-Pin replace is preferred. No need change PCBA. Very urgent. Thanks for your support.
Ash_R_Intel
As per the PDN, there is no recommended replacement part. For your design migration, you will have to check newer families on Intel FPGA. Design changes depend on how many FPGA hard blocks or primitives are directly instantiated. Also if any IPs used, they will also need to be newly generated.
Ash_R_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
