- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Could you confirm the status by running below command?
cat /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/spi-altera.0.auto/spi_master/spi0/spi0.0/pkvl/status
Does this recover over a power cycle?
Do you know how to replicate this issue?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
rsu bmcimg 06:00.0
2020-08-16 21:46:39,075 - [[pci-address(0000:06:00.0),pci_id(0x8086,0x0b30)]] performing RSU operation
2020-08-16 21:46:39,076 - [[pci-address(0000:06:02.2),pci_id(0x8086,0x2f06)]] removing device from PCIE bus
2020-08-16 21:46:41,803 - waiting 10 seconds for boot
2020-08-16 21:46:51,813 - rescanning PCIE bus: /sys/devices/pci0000:00/pci_bus/0000:00
2020-08-16 21:46:57,814 - RSU operation complete
---"power cycle" won't work
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
So, correct me if im wrong here...
rsu bmcimg --> wont recover?
power cycle --> wont recover?
Always on the same ports i.e. 0,5,6 always UP? even after rsu bmcimg or power cycle?
Can you check on another card on the same machine? How many cards are showing this problem?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
yes, not recovered. yet now I got one card in my hand. it seems that c827 firmware works wrong ? any method to update it ?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi, I think these are different case.
The first card, if the problem follows the card. it might be the card problem. Could you provide the card S/N?
The 2nd card, there is no upgrade to the retimer needed. What is the message that you see on the fpgainfo phy? Is the problem consistent on every power up?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The first card:the card S/N(644c36110378)
The 2nd card:currently no more card
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
