Booting NIOS II from Altera Serial Flash Controller (EPCQ) with blinking LEDs
cancel
Showing results for
Search instead for
Did you mean:
340 Discussions
Intel FPGA Wiki:Booting NIOS II from Altera Serial Flash Controller (EPCQ) with blinking LEDs
(Redirected from Booting NIOS II from Altera Serial Flash Controller (EPCQ) with blinking LEDs)
  • Booting NIOS II from Altera Serial Flash Controller (EPCQ) with blinking LEDs design example
Overview
A design of booting NIOS II processor from EPCQ flash with blinking LEDs is presented here. This design was created following the AN-736 Nios II Processor Booting From Altera Serial Flash (EPCQ), utilizing Cyclone V SOC development board. If another device would be targeted for this project, the user can change the targeted device in this example to any required device, with the following steps:
  • Change the device family from Assignment tab > Device > Device family.
  • Change the pin assignments for the reset signal (Push button) and the clock source, from Assignments tab > pin planner.
  • Change the EPCQ/S model in EPCQ_CONTROLLER IP according to the user board specifications.
The Design file can be downloaded from here File:NIOS DEBUG.zip.
Hardware considerations
The snapshot below elaborates the basic Qsys system required for booting NIOS II from EPCQ flash.
b/b8/Qsys_Snapshot.GIF
Please Note the following points:
  • The NIOS II reset vector points to the EPCQ controller, with some reset offset value.
  • The NIOS II exception vector points to the On-chip ram.
  • The maximum frequency allowed for the Altera serial flash controller is 25MHz. Hence, to use a higher frequency for NIOS II, a PLL would be used in the design, to maintain the data synchronization.
Software considerations
The user must consider the bsp settings according to AN 736.
NOTE: This Project works on NIOS II/f core only, since NIOS II/e core is not able to boot from EPCQ.
Version history
Last update:
‎06-27-2019 07:12 PM
Updated by:
Contributors
