Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
- read transfers
- write transfers
- minimum required setup - 3 components
- maximum tested limit - 15 components
NOTE: In v14.1 and later, the JTAG Debug Link is auto-instantiated and is not a selectable IP core from the IP Catalog.
- Place mouse cursor on a graph
- Use mouse to right-click on the statistics panel
- When not in use, turning off your instrumentation setup saves system resources.
- example: Adding or removing a master or slave component from your Qsys system.
- example: Adding or removing a performance monitor from the Instrumentation Panel.
- example: Turning off and turning back on your current instrumentation setup.
- When monitoring a master, you can see how many data reads per second that this master achieves from all its slaves.
- When monitoring a slave, you can see how many data reads per second that this slave is delivering to all its masters.
- When monitoring a master, you can see how many data writes per second that this master can get write commands into the fabric.
- When monitoring a slave, you can see how many data writes per second that this slave can accept write commands from all its masters.
Bus Analyzer Toolkit (Beta) - Feedback
We are actively planning work on the Bus Analyzer Toolkit to be released in a future version of Quartus II software. To that end, we would like to prioritize the work we do. Could you answer the following:
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
