GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
473 Discussões
Apex Legends issues on the Intel Arc b580 graphics card
OrixoN
Novo colaborador I
10.805 Visualizações
Hello, I’m experiencing a graphics issue in Apex Legends where:
  1. Ground textures never load correctly and always appear extremely low-resolution, blocky, or corrupted. This happens throughout the entire match, not just when viewing from the dropship.(See screenshot(The screenshot was taken from another discussion.))
  2. A recent update introduced a snow problem on one of the maps (Since you have a size limitation, here is a link to the video of the second point: https://drive.google.com/file/d/1maCzoxXX_1Sbp3xy9d4OMMvU3biOjl3_/view?usp=sharing)
  3. I've been struggling with the first point for a year now, but I've almost gotten used to it, but another 2nd point has appeared.
System Specs:
  • GPU: Intel Arc B580 (12 GB VRAM)
  • CPU: Ryzen 5 8400f
  • RAM: 32 GB DDR5
  • OS: Windows 11 (64-bit, fully updated)
  • Drivers: Intel Arc Graphics – 32.0.101.8425
  • BIOS: Resizable BAR enabled
  • Report for intel graphics driver in attach
Settings Tested:
  • Texture Streaming Budget: Tested all
  • Texture Filtering: 16x Anisotropic
  • Adaptive Resolution: OFF
  • Anti-Aliasing: TSAA
  • Model Detail: High
Issue Details:
  • Ground textures (grass, dirt, farmland, etc.) appear pixelated, blotchy, and low-detail at all times, even when standing right on them.
  • Textures do not seem to properly load into high resolution, despite sufficient VRAM and system RAM.
  • Other games on the same hardware display textures normally, so this seems isolated to Apex Legends.
  • On the other map, I understand that the reflection on the snow is very bad, or there is a problem with the lighting (I don’t really understand)
Steps Tried:
  1. Updated GPU drivers (latest Intel Arc drivers).
  2. Updated Windows.
  3. Enabled ReBAR in BIOS.
  4. Verified game files.
  5. Adjusted all relevant graphics settings (textures, filtering, adaptive resolution, etc.).
  6. I reinstalled Windows on both 10 and 11.
Result: Issue persists across all settings and tests.
If there's anything else that needs to be added, let me know and I'll send it as soon as I can.
33 Respostas
MichaelRead
Principiante
9.340 Visualizações
I am also experiencing the same graphical issues with Apex legends with my Intel Arc B580.
I have the exact same issues as Orionx. I too can live with the poor ground textures on Storm point being very pixellated and not loading correctly. However with the latest issue regarding the snow glitching out - as seen in the shared video  above https://drive.google.com/file/d/1maCzoxXX_1Sbp3xy9d4OMMvU3biOjl3_/view?usp=sharing
It renders the game impossible to play!
It is really frustrating.
Please can you update the drivers accordingly, liase with EA if its an issue on their side.
We paid for a graphics card that simply isn't doing its job.
Looking forward to some updates regarding this asap.
Kind regards,
Michael
MichaelRead
Principiante
9.335 Visualizações
Thank you for sharing this!
I thought I was alone with these issues and had been gritting my teeth through Storm Point Maps.
This new snow issue is unacceptable!
I hope we get some answers soon!
Thanks for a really detailed summary of the issues we have all been experiencing!
Michael
OrixoN
Novo colaborador I
9.332 Visualizações
It's unfortunate that we have this problem, but it's also good that someone else has found this problem, so I hope it'll be resolved sooner. We're looking forward to hearing from support about any questions or solutions regarding this issue!
Cambodunum
Novato
9.320 Visualizações
2026-02-15 20_32_35-Apex Legends.pngFor me the same. Before I had only problems at Storm Point:
OrixoN
Novo colaborador I
9.298 Visualizações
The recent driver update from February 16th also did not help solve the problem, so I'm writing this just in case.
Xanveer
Principiante
9.232 Visualizações
I'm also facing similar issues
AAA137
Novato
9.061 Visualizações
My game is having the same issue.
  • Driver Versions: 32.0.101.8509
  • Intel Arc: B580
  • CPU: R5 5600
  • RAM : 16GB
OrixoN
Novo colaborador I
8.939 Visualizações
Sorry, I didn't send a screenshot of the problem in point 1. Here it is.
OrixoN
Novo colaborador I
8.938 Visualizações
Details on this issue: when I get closer, these squares disappear.
Hardus
Principiante
8.836 Visualizações
I just wanted to reply to your post and confirm that I am experiencing the exact same issues on my Intel Arc B580.
The ground textures are extremely low-resolution and pixelated, especially on Storm Point, and they do not properly load even when standing right next to them. The recent snow glitch on World’s Edge is even worse and makes certain areas almost unplayable.
I have tried everything as well:
  • Clean driver installation (including DDU)
  • Latest drivers installed
  • Windows fully updated
  • ReBAR enabled
  • Verified game files
  • Adjusted all in-game graphics settings
Nothing has resolved the issue.
I also tested by switching back to my previous GPU (Radeon RX 480), and the problem disappears completely, so it definitely seems specific to the Arc B580.
It’s reassuring (in a way) to see that others are experiencing the same issue, as it suggests this is not an isolated hardware fault but possibly a driver or compatibility problem that needs to be addressed.
Hopefully Intel can investigate this properly and provide a fix soon.
ChloeLouCryssie
Principiante
8.682 Visualizações
I'm experiencing the exact same issue. I had the texture issues on Stormpoint but wasn't affecting my gameplay. Now this issue on Worlds Edge makes it completely unplayable. I'm avoiding running ranked on the days of Worlds Edge. It's visually awful and I've had so many people comment on it on stream too. This started with the new season and we still don't have a fix. Very disappointing.
Chloe
AAA137
Novato
8.578 Visualizações
Update : Driver 32.0.101.8531
Intel: ARC B580
CPU: R5 5600
RAM: 16 GB
GAME: Apex legends Maps world edge.
I've updated the drivers, but the problem is still there.
Cambodunum
Novato
7.247 Visualizações
I just wanted to let you know that I’ve temporarily downgraded my driver again for World’s Edge after finding this comment:
https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/1205#issuecomment-4017529859
Down to version .8331.
I didn’t do a full uninstall with DDU. I only cleared the shader cache once and then ran the Intel installation twice (twice because the first attempt always fails with some error. After the reboot, the second attempt always works for me).
I think the other artifacts will probably remain, but at least there’s no more disco effect on World’s Edge.
OrixoN
Novo colaborador I
7.239 Visualizações
Thanks for the troubleshooting advice. I'll check it out when I have time. The problem is that I'll have to install older drivers, which could cause issues with games that aren't optimized for older driver versions (like Resident Evil: Requiem). Still, thank you very much for your response. I hope the more comments you get, the faster Intel support will resolve this issue!
OrixoN
Novo colaborador I
7.214 Visualizações
problemy).
No, I haven't tried that. I'll write about my problem a little later in the thread you linked. I'll probably also duplicate our entire thread there (the main issues).
Ems1
Principiante
7.083 Visualizações
Have they fixed it yet
OrixoN
Novo colaborador I
7.057 Visualizações
No, they haven't fixed it yet. I hope they at least looked at this thread.
Ar1ze
Principiante
6.775 Visualizações
Unfortunately we face these kind of issues, and it seems like the team still not yet done on graphics demanding titles, while most of intel gpu consumers are budget FPS Gamers. Hopefully they fix this issue soon or they will lose a lot of consumers
Specs:
R5 7500F
ASROCK B580 INTEL ARC
KLEVV RAM 32 GB 6000MHZ
JipZeonGit
Novato
4.218 Visualizações
Dear Arc B580 users,
I would like to thank everyone in the community for your support and shared feedback. I am also an Arc B580 user, and I, too, have been deeply plagued by this exact issue for a long time.
I want to share some good news: I have already escalated this issue directly to the Intel Engineering team via a formal support ticket (Case ID: 06819152).
The engineering team has officially acknowledged this as a known driver-level rendering problem affecting the Arc B580 community. They are currently investigating it as a priority for an upcoming driver fix.
To provide transparency on their progress, the team has finally published an official Knowledge Base (KB) article regarding these specific texture and scenery issues (updated on March 23th)
 https://www.intel.com/content/www/us/en/support/articles/000101933/graphics.html
Therefore, Intel engineers already have all the data and logs they need, and the issue is officially documented.
Please refer to the KB article, hang tight, and let's wait for the upcoming driver update. A real fix is actively in the works!
Zeongit Jip
Responder
