- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I've been getting CL_INVALID_KERNEL_ARGS for all my kernels after updating to the latest intel driver version.
I ran into this when I was getting ".1" appended to my kernel names, where I updated to the latest driver to try and fix it.
I methodically tried installing all previous driver versions and the first version to not give me the CL_INVALID_KERNEL_ARGS was 30.0.101.1340.
Did something change in subsequent driver versions that would cause SPIR-V consumption to go wrong?
Here is the cpp code to duplicate the issue:
#include "CL/cl.h"
#include <iostream>
#include <fstream>
#include <vector>
#define MAX_PLATFORM_SIZE 256
#define MAX_DEVICE_SIZE 256
namespace {
std::vector<unsigned char> load_file(const std::string& file)
std::fstream input(file, std::ios::in | std::ios::binary | std::ios::ate);
auto size = input.tellg();
input.seekg(0, std::ios::beg);
std::vector<unsigned char> binary(size);
input.read((char*)binary.data(),size);
input.close();
return binary;
void check_error(int result,int line){
if(result != CL_SUCCESS){
throw std::runtime_error(std::to_string(line) + std::string(": error: ") + std::to_string(result));
int main()
std::vector<unsigned char> data = load_file("window_level.spv");
// Get platform and device information
cl_device_id device_id[256];
cl_platform_id platform_id[256];
cl_uint ret_num_devices;
cl_uint ret_num_platforms;
char buf[4096];
cl_int ret = clGetPlatformIDs(0, 0, &ret_num_platforms);
check_error(ret,__LINE__);
ret = clGetPlatformIDs(ret_num_platforms, platform_id, &ret_num_platforms);
for (unsigned int i=0; i<ret_num_platforms; i++)
ret = clGetPlatformInfo(platform_id[i], CL_PLATFORM_NAME, sizeof(buf), buf, NULL);
ret = clGetDeviceIDs(platform_id[i], CL_DEVICE_TYPE_ALL, MAX_DEVICE_SIZE, device_id, &ret_num_devices);
for (unsigned int j=0; j<ret_num_devices; j++) {
ret = clGetDeviceInfo(device_id[j], CL_DEVICE_NAME, sizeof(buf), buf, NULL);
ret = clGetDeviceInfo(device_id[j], CL_DEVICE_VENDOR, sizeof(buf), buf, NULL);
// Create an OpenCL context
cl_context context = clCreateContext( NULL, 1, &device_id[0], NULL, NULL, &ret);
// Create a command queue
cl_command_queue command_queue = clCreateCommandQueueWithProperties(context, device_id[0], 0, &ret);
cl_ulong max_constants_size = 0;
ret = clGetDeviceInfo(device_id[0], CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE, sizeof(max_constants_size), &max_constants_size, NULL);
// create some images
cl_image_format image_format_gray16s;
image_format_gray16s.image_channel_data_type = CL_SIGNED_INT16;
image_format_gray16s.image_channel_order = CL_R;
int width = 512;
int height = 512;
std::vector<short> slice(512*512, 0);
cl_image_desc image_desc_gray16s;
image_desc_gray16s.image_type = CL_MEM_OBJECT_IMAGE2D;
image_desc_gray16s.image_width = width;
image_desc_gray16s.image_height = height;
image_desc_gray16s.image_depth = 1;
image_desc_gray16s.image_array_size = 1;
image_desc_gray16s.image_row_pitch = 0;
image_desc_gray16s.image_slice_pitch = 0;
image_desc_gray16s.num_mip_levels = 0;
image_desc_gray16s.num_samples = 0;
image_desc_gray16s.buffer = NULL;
cl_mem cl_image_gray16s = clCreateImage(
context,
CL_MEM_READ_ONLY,
&image_format_gray16s,
&image_desc_gray16s,
NULL,
&ret
size_t origin[] = {0,0,0};
size_t region[] = {(size_t)width,(size_t)height,1};
ret = clEnqueueWriteImage(
command_queue,
cl_image_gray16s,
CL_TRUE,
origin,
region,
width*sizeof(signed short),
0,
slice.data(),
0,
NULL,
NULL
cl_image_format image_format_gray8;
image_format_gray8.image_channel_data_type = CL_UNSIGNED_INT8;
image_format_gray8.image_channel_order = CL_R;
cl_image_desc image_desc_gray8;
image_desc_gray8.image_type = CL_MEM_OBJECT_IMAGE2D;
image_desc_gray8.image_width = width;
image_desc_gray8.image_height = height;
image_desc_gray8.image_depth = 1;
image_desc_gray8.image_array_size = 1;
image_desc_gray8.image_row_pitch = 0;
image_desc_gray8.image_slice_pitch = 0;
image_desc_gray8.num_mip_levels = 0;
image_desc_gray8.num_samples = 0;
image_desc_gray8.buffer = NULL;
cl_mem cl_image_gray8 = clCreateImage(
context,
CL_MEM_WRITE_ONLY,
&image_format_gray8,
&image_desc_gray8,
NULL,
&ret
cl_int error = 0;
cl_program program = clCreateProgramWithIL(context,data.data(),data.size(),&error); // TODO
// Build the program
ret = clBuildProgram(program, 1, &device_id[0], NULL, NULL, NULL);
std::string kernel_name;
size_t ret_val_size = 0;
ret = clGetProgramInfo(program, CL_PROGRAM_KERNEL_NAMES, 0, NULL, &ret_val_size);
kernel_name.resize(ret_val_size+1);
ret = clGetProgramInfo(program, CL_PROGRAM_KERNEL_NAMES, ret_val_size, kernel_name.data(), NULL);
kernel_name[ret_val_size] = '\0';
// Create the OpenCL kernel
cl_kernel kernel = clCreateKernel(program, kernel_name.c_str(), &ret);
// Set the arguments of the kernel
ret = clSetKernelArg(kernel, 0, sizeof(cl_mem), (void *)&cl_image_gray16s);
ret = clSetKernelArg(kernel, 1, sizeof(cl_mem), (void *)&cl_image_gray8);
float window_width = 1000.0f;
float window_level = 0.0f;
float half_window_width = window_width/2;
float window_bottom = window_level - half_window_width;
float reciprocal_width = 255.0f / window_width;
ret = clSetKernelArg(kernel, 2, sizeof(float), (void *)&window_bottom);
ret = clSetKernelArg(kernel, 3, sizeof(float), (void *)&reciprocal_width);
// Execute the OpenCL kernel on the list
size_t local_work[3] = {8, 8, 1};
size_t global_work[3] = {(size_t)(local_work[0] * (size_t)ceilf((float)width/local_work[0])), (size_t)(local_work[1] * (size_t)ceilf((float)height/local_work[1])), 1};
ret = clEnqueueNDRangeKernel(
command_queue,
kernel,
2,
NULL,
global_work,
local_work,
0,
NULL,
NULL
// error -52: CL_INVALID_KERNEL_ARGS
return 0;
I generate the spirv file via clang-15 and llvm-spriv-15:
clang -target spirv64 -emit-llvm -O1 -c -o window_level.bc window_level.clcpp
llvm-spirv -spirv-max-version=1.2 -o window_level.spv window_level.bc
the actual kernel:
kernel void window_level(
__read_only image2d_t wl_image,
__write_only image2d_t dst_image,
float window_bottom,
float width_rcp
int2 coords2d;
coords2d.x = get_global_id(0);
coords2d.y = get_global_id(1);
int4 wl_sample = read_imagei(wl_image, coords2d);
int4 dst_value;
dst_value.x = clamp((int)(wl_sample.x - window_bottom) * width_rcp,0.0f,255.0f);
write_imagei(dst_image, coords2d, dst_value);
I've attached the SPIR-V file too.
System Setup Information:
System Used: Inspiron 3670
CPU SKU: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz 3.60 GHz
GPU SKU: Intel(R) UHD Graphics 630
System BIOS Version: Dell Inc. 1.3.4, 24/05/2018
Graphics Driver Version: 30.0.101.1069
Operating System: Windows 10 Pro
OS Version: 10.0.19042 Build 19042
API: OpenCL
Occurs on non-Intel GPUs?: no tested
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thank you for posting in the Intel forums.
Since this is a duplicate thread of https://community.intel.com/t5/GPU-Compute-Software/OpenCL-Kernel-Name-appends-quot-1-quot/m-p/1419720#M644, we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Thanks & Regards,
Santosh
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
This is not really a duplicate thread, its an additional issue discovered in the original thread.
The advice in that thread to upgrade the driver fixed the ".1" name issue, but exposed another CL_INVALID_KERNEL_ARGS issue.
I'm not certain they are the same issue, so I posted another issue here to get advice on that.
Scott
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
