- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi all,
I have just upgraded to the latest Intel Graphics Driver and I can no longer build opencl programs from spirv. It seems image3d write is broken/missing as I get the following error for a simple opencl kernel:
failed to build opencl program:
error: undefined reference to `__builtin_spirv_OpImageWrite_img3d_wo_v3i32_v4f32'
in function: '__builtin_spirv_OpImageWrite_img3d_wo_v3i32_v4f32' called by kernel: 'driver_test2'
error: backend compiler failed build.
here is a simple kernel that triggers this:
#include <opencl_memory>
#include <opencl_work_item>
#include <opencl_image>
#include <opencl_integer>
using namespace cl;
kernel void driver_test(
image3d<float4, image_access::write> dst_vol
const int3 dst_coords(get_global_id(0), get_global_id(1), get_global_id(2));
float4 source_sample(0.0f,0.0f,0.0f,0.0f);
dst_vol.write(dst_coords, source_sample);
and the cpp part:
#include "CL/cl.h"
#include <iostream>
#include <fstream>
#define MAX_PLATFORM_SIZE 256
#define MAX_DEVICE_SIZE 256
std::vector<unsigned char> load_file(const std::string& file)
std::fstream input(file, std::ios::in | std::ios::binary | std::ios::ate);
auto size = input.tellg();
input.seekg(0, std::ios::beg);
std::vector<unsigned char> binary(size);
input.read((char*)binary.data(),size);
input.close();
return binary;
void driver_test()
std::vector<unsigned char> data = load_file("driver_test.spir");
cl_device_id device_id[256];
cl_platform_id platform_id[256];
cl_uint ret_num_devices;
cl_uint ret_num_platforms;
char buf[4096];
cl_int ret = clGetPlatformIDs(0, 0, &ret_num_platforms);
ret = clGetPlatformIDs(ret_num_platforms, platform_id, &ret_num_platforms);
if (ret != CL_SUCCESS) {
std::cout << "something went wrong in clGetPlatformIDs" << std::endl;
return;
for (unsigned int i=0; i<ret_num_platforms; i++)
ret = clGetPlatformInfo(platform_id[i], CL_PLATFORM_NAME, sizeof(buf), buf, NULL);
std::cout << "something went wrong in clGetPlatformInfo" << std::endl;
return;
std::cout << "Platform[" << i << "]: " << buf << std::endl;
ret = clGetDeviceIDs(platform_id[i], CL_DEVICE_TYPE_ALL, MAX_DEVICE_SIZE, device_id, &ret_num_devices);
std::cout << "something went wrong in clGetDeviceIDs" << std::endl;
return;
for (unsigned int j=0; j<ret_num_devices; j++) {
ret = clGetDeviceInfo(device_id[j], CL_DEVICE_NAME, sizeof(buf), buf, NULL);
std::cout << "something went wrong in clGetDeviceInfo" << std::endl;
return;
std::cout << "Device Name: " << buf << std::endl;
ret = clGetDeviceInfo(device_id[j], CL_DEVICE_VENDOR, sizeof(buf), buf, NULL);
return;
std::cout << "Device Vendor: " << buf << std::endl;
std::cout << std::endl;
cl_context context = clCreateContext( NULL, 1, &device_id[0], NULL, NULL, &ret);
cl_int err = 0;
cl_program program = clCreateProgramWithIL((cl_context)context, data.data(), data.size(), &err);
if(err != CL_SUCCESS){
std::cout << "failed to create opencl program with IL " << std::endl;
return;
// sometimes crashes here
err = clBuildProgram(program, 1, &device_id[0], NULL, NULL, NULL);
cl_int build_status;
err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_STATUS, sizeof(cl_build_status), &build_status, NULL);
if(build_status != CL_SUCCESS){
size_t ret_val_size;
err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_LOG, 0, NULL, &ret_val_size);
std::vector<char> build_log(ret_val_size+1,0);
err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_LOG, ret_val_size, build_log.data(), NULL);
build_log[ret_val_size] = '\0';
std::cout << "failed to build opencl program: \n" << build_log.data() << std::endl;
I've been rolling back the driver versions and the earliest driver where this happens is: 30.0.101.1069
Earlier driver version work fine
Sometimes it crashes at clBuildProgram too.
I have attached the .cl, cpp and .spir files. We use:
SPIRV-LLVM
SPIR
libclcxx
to generate the spirv file. I've attached the generated spirv for easier testing.
Any help would be appreciated.
Scott
System Setup Information:
System Used: Inspiron 3670
CPU SKU: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz 3.60 GHz
GPU SKU: Intel(R) UHD Graphics 630
System BIOS Version: Dell Inc. 1.3.4, 24/05/2018
Graphics Driver Version: 30.0.101.1069
Operating System: Windows 10 Pro
OS Version: 10.0.19042 Build 19042
API: OpenCL
Occurs on non-Intel GPUs?: no tested
- タグ:
- opencl
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@Scott_S_2 One post is enough. Stay with your original post.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@AlHill the system continuously marked my posts as SPAM, without any extra information, hence the weird state of multiple posts appearing
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Well, the system did not mark as spam the multiple post that I saw.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thanks for the thorough description and the reproducer!
As best I can tell, the issue is caused by using a three-component vector as the image coordinate for the 3D image write:
The SPIR-V spec - and specifically the OpenCL SPIR-V environment spec - isn't clear whether this should be supported or not. But, since the corrosponding OpenCL C function takes a four-component vector as the image coordinate for a 3D image write, it looks like this is the only SPIR-V version we currently have implemented in our compiler:
I'll try to think if there is a workaround for this issue.
In the meantime, I'd suggest filing an OpenCL spec issue to clarify whether three-component coordinates are valid for 3D image writes, or if four-component coordinates are required:
https://github.com/KhronosGroup/OpenCL-Docs/issues
PS: For whatever it's worth, our CPU OpenCL device does not seem to be accepting the three-component vector either.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
This is interesting, although confusing as the previous driver versions seem to handle this fine. I'm guessing something has changed between versions with the SPIRV handling.
I also get errors with regular C kernels when using LLVM 15 and LLVM-SPIRV generated spirv e.g.
__kernel void window_level(
__read_only image2d_t srcImg,
__write_only image2d_t dstImg,
float window_bottom,
float width_rcp
int2 coord = (int2) ((int)get_global_id(0), (int)get_global_id(1));
int2 size = get_image_dim(srcImg);
if(coord.x >= size.x || coord.y >= size.y){
return;
sampler_t sampler = CLK_FILTER_NEAREST | CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_CLAMP;
int4 src_value = read_imagei(srcImg, sampler, coord);
int4 dst_value;
dst_value.x = (int)((src_value.x - window_bottom) * width_rcp);
if(dst_value.x > 255){ dst_value.x = 255; }
if(dst_value.x < 0){ dst_value.x = 0; }
write_imagei(dstImg, coord, dst_value);
gives me the following error
error: undefined reference to `__builtin_spirv_OpImageWrite_img2d_wo_v2i32_v4i32_i32'
in function: '__builtin_spirv_OpImageWrite_img2d_wo_v2i32_v4i32_i32' called by kernel: 'window_level.1'
So this seems to be a common issue with newer driver versions.
I can't just change the coords to int4 as it complains that write_imagei cannot convert the input from int4 to int2, and dst_vol.write(dst_coords, source_sample) cannot convert from int4 to int3 etc.
In the meantime I'll post in the OpenCL-Docs issue tracker.
Scott
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
for this particular C kernel case: passing -spirv-max-version=1.2 solves the 2D undefined reference issue
